Point to Point Link between Nexus VPC Domains - this works but is it correct ?
Cormac Champion
Hi all
I'm creating a Point to Point link between two Nexus Domains.  I have done the following and it works, but is this correct or are there potential issues with this.
I'm passing this Vlan off through another pair of switches in a vpc domain, which are trunked
Domain A
Switch 1 - Vlan 99 / IP Address 10.99.1.2/29 / HSRP 1 / IP 10.99.1.1
Switch 2 - Vlan 99 / IP Address 10.99.1.3/29 / HSRP 1 / IP 10.99.1.1
v
Another VPC Domain X - Trunk Incl Vlan 99
v
Another VPC Domain Y - Trunk Incl Vlan 99
v
Domain B
Switch 1 - Vlan 99 / IP Address 10.99.1.4/29 / HSRP 2 / IP 10.99.1.6
Switch 2 - Vlan 99 / IP Address 10.99.1.5/29 / HSRP 2 / IP 10.99.1.6
Ok, if point-to-point is on a separate subnet/vlan than it should work fine.  Make sure to test the connectivity by downing one site at a time and to make HSRP functioning and failing over as expected.
Reza Sharifi
Not sure how your environment is setup but I would not use a user vlan (99) that is trunked somewhere else as part of the point-to-point connection. I would use a separate vlan/subnet just for the point-to-point connection.
Sorry, this IS a separate Vlan and subnet - used ONLY for the purpose of a point to point link.
This this an acceptable way to complete this or is there another way in which it should or could be done ?
