Policier on Layer 3 SVI
noobieee7
Hi all,
I am having some issue with doing policing on Layer 3 SVI.
This is my configuration
  Policy Map INGRESS-400M
    Class class-default
      police 400000000 bps 50000000 byte conform-action transmit exceed-action drop
  Policy Map EGRESS-400M
     Class class-default
interface GigabitEthernet1/5
switchport trunk allowed vlan 100-300
switchport mode trunk
switchport nonegotiate
qos vlan-based
interface Vlan100
ip address 10.0.0.1 255.255.255.240
standby 7 ip 10.0.0.3
standby 7 priority 140
standby 7 preempt
service-policy input INGRESS-400M
service-policy output EGRESS-400M
end
show policy-map int vlan 100
Vlan100
  Service-policy input: INGRESS-400M
    Class-map: class-default (match-any)
      0 packets
      Match: any
        0 packets
      police: Per-interface
        Conform: 0 bytes Exceed: 0 bytes
  Service-policy output: EGRESS-400M
      524952 packets
      Match: any
        524952 packets
As you can see there is not matching packets at the INGRESS policy map and on the EGRESS policy map the conform is : 0
Any idea why it is so?
6 Replies 6
Lei Tian
On what platform?
Lei Tian
Hi Lei Tian,
It's on a cisco 4510
The configure looks fine to me. Did you have qos turn on globally? Do you see policing not working, or only the counter not working?
Another thing about vlan based policing is the policer will affect all traffic pass the vlan, not per port based. If you want to per-port per-vlan, you can do it on inteface using 'vlan range'.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sg/configuration/guide/qos.html#wp1338610
HTH,
Lei Tian
Hi Lei Tian,
Thanks for the information. But I do see a spike in the CPU utilisation once I enabled QOS. Is that a norm?
Policing is handled by hardware, you shouldn't see high cpu after enable qos.
Check this link to troubleshooting high cpuon 4500
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
HTH,
Lei Tian
danrya
I want to clarify one thing:
The policer is on the SVI, but the traffic that will be policed is L2 traffic on the switch ports.  It's not the same as policing on a L3 physical port.
Are there any ports on this switch that belong to VLAN100 besides the trunk?
Dan
