Policing to 100Mbps with the same policy-map over different interfaces service-policy in routers
We have many different interfaces in our routers. On these we have service-policys to limit bandwith to 100Mbps.
If we use a class-map matching an access-list like "permit ip any any"
and a policy-map with that class-map to police down to 100Mbps.
If we apply that policy map as interface service-policy out. Would all interfaces that are using that service-policy share 100Mbps or will they get 100Mbps each?
Thanks for any reply.
Henrik
2 Accepted Solutions
Reza Sharifi
Since you are applying the policy per interface, each interface will get 100Mb
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
And another note, if you set polices on router subinterfaces, the policer would be effective per subinterface (independently of other subinterfaces on the same main interface).
Reza Sharifi
Thank you
Disclaimer
Posting
Thank you both and yes in our Case it is applied to subinterfaces.
