Policy Based Routing breaks DHCP on ASA 5525X ?!!
Ahmed ElShanab
Hi.
I have a setup working on a Cisco ASA 5525 X
This is the configuration for DHCP and PBR1:
interface Redundant1
member-interface GigabitEthernet0/2
member-interface GigabitEthernet0/3
no nameif
no security-level
no ip address
interface Redundant 1.111
VLAN 111
nameif Inside1
security-level 100
ip address 172.16.111.1 255.255.255.0
policy-route route-map PBR1
access-list PBR1 extended permit ip any any
access-list Inside1 extended permit ip any any
nat (Inside1,outside) source dynamic any interface
access-group Inside1 in interface Inside1
route-map PBR1 permit 10
match ip address PBR1
set ip next-hop 192.168.250.11
dhcpd dns 8.8.8.8 4.4.2.2
dhcpd address 172.16.111.2-172.16.111.254 Inside1
dhcpd enable Inside1
When I remove the PBR1 from interface Redundant 1.111 DHCP working fine, but when I add it DHCP not working .
Any one has any idea of what could be going on here ???
I believe that the issue here is that the acl used for PBR does a permit ip any any, so when the DHCP request is received on the interface it is not processed by DHCP but is forwarded to 192.168.250.11. I suggest that you modify the acl so that it denies DHCP requests before it matches other traffic. And I might suggest that instead of permitting any source address that you permit traffic from the subnet configured on that interface.
Rick
Hello
Not sure what you mean by the above statement but your PBR is policy routing all traffic origninating from vlan 111 to that specified next hop which seems to be causing you an issue.
Kind Regards
Paul
Rick
I am glad that my suggestion was helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
