Policy based routing catalyst 3750
jorg.ramakers
When I want to configure policy based routing. When i want activated it on a vlan interface it won't work.
I don't have the option ip policy route-map
The command policy is not known...
Equipment i'm using is Catalyst 3750. Ios ipbase 12.2(25)SEE4
Best regards
Jorg
2 Accepted Solutions
Jon Marshall
Jorg
You need to be running the right SDM template on the switch as there are a different number of possible templates. From memory i believe it is the routing template you need. See attached link for template details -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sec/configuration/guide/swsdm.html
Jon
alan.blake
Jon Marshall
Jorg
Jon
Hi Jon,
Thanx for the tip. You need indeed enable pbr by the template and it is necessary to run at least ipservices instead of ipbase.
Tnx
Jorg
alan.blake
whoops.
