Policy Based Routing & GLBP
We are currently running HSRP, as our redundancy protocol, on our routers.  Our site has two WAN connection.  One is an MPLS, and the other is a VPN GRE IPSec tunnel.  We have Policy Based Routing that routes certain traffic over the VPN tunnel, and other traffic over the MPLS cloud.  If I moved to GLBP, from HSRP, how does that affect the policy based routing, if I set up a weighted load-balanced round-robin configuration?  Does that affect PBR at all?
John Blakley
Policy routing happens before regular routing, so I would think pbr wouldn't be affected.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
HTH,
John
John,
Thank you for your reply!  I kind of thought that the PBR would happen, then regular routing via the load-balanced gateway.  Again, thanks for your reply!  Have a great day!
