Vlan communication problem
ciscouser2013
Hello Forum,
Im having a communication problem in my current setup.
Recently the switches were swapped from 3550 to the 3750-E.
There are a few Vlans configured in the switch and Im having problems with VLAN 2.
The NICS on the server in VLAN 1 are communicating as they should.
The NICS on the server in VLAN 2 are not able to communicate.
This VLAN is being used as the second heartbeat link for VCS, and lltstat shows the link as "DOWN"
#sh vlan shows the vlan as active on both sides.
Are there any tests that I can do to ensure why the NICS in VLAN 2 are not able to communicate with each other?
Thank you
Reza Sharifi
Can you post the config from both switches?
have you enabled IP routing on the switches?
Are NIC 2 in different subnet then NIC 1?
What happen when you put NIC 2 in vlan 1?
Also from both switches what is the output of "sh ip int bri vlan 2"?
glen.grant
  Is the link between the switches separate links or is it a single link trunked? Do all interfaces on both switches show active , including the links between the switches? If you have 2 other devices give them an address in the same subnet and then connect them to the ports you are dealing with and try and ping back and forth. Turn off any device FW's .
Kindly provide the output of show spanning-tree vlan 2 from both the devices & also the output of show interfaces from the two switches.
Also provide the configurations on both the switches to assist ypou further.
Thanks & Regards,
Vignesh R P
