Policy Based Routing Issue
Leon Brierley
Hi all
I am trying to resolve an issue with some PBR on a Cisco 3850. Basically, i want to route internet traffic for one specific vlan to a new firewall
I have created a test SVI (vlan 888 - 10.77.88.254/24) and i am matching traffic with a souce IP of 10.77.88.0/24 (ip default next-hop - new firewall ip) All other SVIs should route via the old firewall and the switch has a route to this (10.0.0.0/8 via old firewall ip)
I have a client PC in the test vlan 888, when i apply the policy to the SVI and turn on Policy Routing debugging i see the below messages
198391: Jul 13 11:06:05: IP: route map INTERNET, item 10, permit
198392: Jul 13 11:06:05: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 78, policy rejected -- normal forwarding
198393: Jul 13 11:06:06: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 78, policy match
198394: Jul 13 11:06:06: IP: route map INTERNET, item 10, permit
198395: Jul 13 11:06:06: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 78, policy rejected -- normal forwarding
198396: Jul 13 11:06:07: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 78, policy match
198397: Jul 13 11:06:07: IP: route map INTERNET, item 10, permit
198398: Jul 13 11:06:07: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 78, policy rejected -- normal forwarding
198399: Jul 13 11:06:20: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 78, policy match
198400: Jul 13 11:06:20: IP: route map INTERNET, item 10, permit
198401: Jul 13 11:06:20: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 78, policy rejected -- normal forwarding
198402: Jul 13 11:06:20: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 236, policy match
198403: Jul 13 11:06:20: IP: route map INTERNET, item 10, permit
198404: Jul 13 11:06:20: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 236, policy rejected -- normal forwarding
198405: Jul 13 11:06:20: IP: s=10.77.88.1 (Vlan888), d=10.77.88.255, len 78, policy match
It seems the policy is rejected and then matched, over and over. I believe what should happen is that if a route exists, then normal forwarding should take place, but if no route exists then the packet should be policy-routed
Can anyone help decipher what is going on with this?
Many thanks
Leon
17 Replies 17
Thanks Peter. Yes, looks like it should. I think now that there is some kind of asymetric routing going on with the new firewall. There appears to me some messages in the syslog on there..
Hi Leon,
Okay. I am not entirely sure if you consider this issue to be covered sufficiently so please feel more than welcome to revisit this thread and ask further.
Best regards,
Peter
Hi Peter
Managed to get to the bottom of this in the end. So the PBR was working (ip next-hop) but the ASA was dropping TCP packets as there was some asymmetric routing created by the PBR. I fixed this by using TCP state bypass for local addresses. Thanks for your help with this
Leon
