Change management interface to access interface
_Ratha_
Level 3
Level 3
Dear all,
Currently, I am running Cisco ASA 5510. all interface are used and I need one more interface for additional requirement.
Can I use management interface to access interface?
How to do that?
luckymike33
Level 6
Level 6
Hi Ratha,
I am not sure I understand the issue here - normally you configure sub-interfaces to allow 'creation' of more interfaces. These are normally port-channeled back to your switch, then that interface is vlan tagged and that is a 'new' interface. I think you could also use the management interface in the data-plane but you need to remove the management-only command.
If that is not the information you are looking for - shout back.
Best wishes
Mike
