policy based routing not working on cisco 6509
zafar_118
i have following topology
Cleint ip address: 99.99.99.1 --------------> connected on port 1/33
Load balancer: 101.101.101.50 ---------- > connected on port 1/44.
I have configured pbr so that any traffic coming from client on port 1/33 should be directed to load balancer and following are my configs
access-list 197 permit ip host 99.99.99.1 host 4.2.2.2
route-map ingress1 permit 10
match ip address 197
set ip next-hop 101.101.101.50
interface GigabitEthernet1/33
ip address 99.99.99.5 255.255.255.0
ip policy route-map ingress1
interface GigabitEthernet1/44
ip address 101.101.101.5 255.255.255.0
For some reason this doesnt seems to be working. From my cisco switch i can ping to both client and load balancer.
What debug commands i can use here to troubleshoot? Is there any misconfiguration?
John Blakley
debug ip policy
The config looks fine from a pbr perspective. What is your load balancer doing once it receives the packet though? Does it act like a router and forward the packet?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Wilson Bonilla
Level 3
Level 3
Hello Zafar.
You said:
"I have configured pbr so that any traffic  coming from client on port 1/33 should be directed to load balancer and  following are my configs "
But then you configured:
"access-list 197 permit ip host 99.99.99.1 host 4.2.2.2"
So that's not any traffic coming from the client, it just matches traffic between the source host 99.99.99.1 and the destination host 4.2.2.2
what if you try changing to acl to point to any any, like access-list 197 permit ip host 99.99.99.1 any any.
Regards.
Wilson B
zafar_118
Hi Guys,
Thanks for the help. It was an issue on load balancer.
