Policy Based Routing on Catalyst
MaximBudyonny
Level 3
Level 3
Hi All,
I have Catalyst 3750 which operates as L3 switch.
8 routed VLANs 10.0.111.0/27 are configured on it.
All these VLANs were created for different types of guest: WiFi, wired and so on. ACLs on Catalyst 3750 protect my LAN from guests and also protect different type of guests from each other.
But guests want to access Internet.
Corporate security policy requires that guests Internet traffic must go through MS ISA server. With Cisco router I can do it with a help of PBR
Something like:
route-map to-isa permit 10
match ip address ACL_THAT_MATCHES_INET_TRAFFIC
set ip next-hop MS_ISA_IP
But how can I do it with Catalyst switch?
michaelc0n
PBR will work on a cat switch 3750 provided you have the EMI IMAGE...might be worth getting.
interface Vlan2
ip address 10.0.111.1 255.255.255.224
ip policy route-map pbr
access-list 10 permit 10.0.111.0 0.0.0.31
route-map pbr permit 10
match ip address 10
set ip next-hop "isa server"
If that doesn't work how bout VACLs?
Stick with VACL's if you can, PBR can be process intensive.
Than you for advices, but as I know only EMI version of a Catalyst IOS supports this feature.
My C3750-IPSERVICESK9-M, Version 12.2(25)SEC doesn't support this feature.
