policy based routing(PBR) next hop not being detected
David_Beldi
please help, trying to reroute traffic that came from source (192.168.183.220) but for some reason pbr isn't working, its like its not even detecting route maps! I am trying to redirect traffic goint to vlan 10 to vlan 20!
version 15.1
hostname R1
boot-start-marker
boot-end-marker
enable secret 4 06YFDUHH61wAE/kLkDq9BGho1QM5EnRtoyr8cHAUg.2
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name cisco.com
license udi pid CISCO2901/K9 sn FGL163713TC
username R1 password 0 david
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.183.51 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 10
ip address 11.0.10.1 255.255.255.0
ip nat inside
ip policy route-map honR
interface GigabitEthernet0/1.2
encapsulation dot1Q 20
ip address 11.0.20.1 255.255.255.0
ip nat inside
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
ip local policy route-map honR
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 11.0.10.5 22 192.168.183.51 22 extendable
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
access-list 100 permit ip host 192.168.183.220 host 11.0.10.5
access-list 101 permit ip 11.0.10.0 0.0.0.255 any
access-list 101 permit ip 11.0.20.0 0.0.0.255 any
route-map honR permit 10
match ip address 100
set ip next-hop 11.0.20.5
control-plane host
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input ssh
scheduler allocate 20000 1000
end
chrihussey
You need to apply the route map to the G0/0 interface and not the others.
Hope this helps
Hey thanks for your reply, originally i had it like that, i am just trying all the options, just changed it but no luck. :(
version 15.1
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
no ip address
shutdown
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip http server
access-list 100 permit ip host 192.168.183.220 host 192.168.183.51
set ip next-hop 11.0.20.1
control-plane host
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login local
transport input ssh
end
A couple things:
Your access-list changed when you moved it back to G0/0. It should remain:
The fact that you are NATing is also an issue. Any traffic from the 11.0.10.x/24 or 11.0.20.x/24 to 192.168.183.220 is NATed to the G0/0 IP. So the likelihood of 192.168.183.220 seeing any packets from the 11.x.x.x networks is not going to happen. Policy routing may work to the 11.0.20.5, but the return gets NATed and probably gets dropped. If you omit 11.0.20.5 from the NAT it may work.
Better still, if possible, remove the NAT altogether and verify if PBR is working.
Hope that makes sense.
