policy based routing with a firewall
Sandeep Choudhary
Hello Everyone,
I have problem while implementing policy based routing with a firewall.
Let me explain in detail.
I have 2 remote site(Site A-small , Site B - Big) , Site B is connected with HQ with Tunnels 1 and 2 ,  Site B and Site A is connected with Tunnel 9941.
what I want is:
Scenirio for Communication :
1)Site A--------->VPN Router Site B-----------> FW-------------->VPN Router Site B------------------>Central Site
2)Central Site--------->VPN Router Site B-----------> FW---------->VPN Router Site B-------------->Site A
3)Site B--------->FW-------------------->VPN Router Site B------>Central Site
4)Central Site--------->VPN Router Site B-------------------->FW------>Site B
5)Site A--------->VPN Router Site B-----------> Site B(no firewall)
6)Site B--------->VPN Router Site B-----------> Site A(no firewall)
Tunnel 1: 10.13.199.1-2
Tunnel 2: 10.13.199.1-2
Tunnel9941: 172.22.99.1-2
Site A LAN- 10.99.41.0/24
Site B LAN- 10.99.0.0/16
Central LAN - 10.18.0.0/16
If you need full clarification with VSD then please see the pdf file.
Wait for ur reply.
kunalgandhi
Hi Sandeep,
Interesting topology .... Checking the same & will revert u with the result.
Hi Kunal,
Thanks..I will wait.
Dhanywad..
Sandeep
Hi Sandeep,
YES it's achievable !!!
I tried to match your scenarion as much as possible &  tested it in GNS3. Hope it is as per your requirement.
Attached only topology diagram for you reference.
I can attached the entire configuration if you want, but I suggest you to try it first in GNS3. Trust me it will be fun and u will enjoy it ( As I did ). Please revert in case you stuck in setup. I'll guide you.
Kunal Gandhi
Ok I will try at home and let u know the results.
BTW thanks for hard work.
Sandeep
