policy-map not supported
faamin011
Switch1(config-if)#service-policy input POLICE
%QoS: policy-map with police action at parent level not supported on Tunnel0 int
erface.
Master SVI send all failed for interface Tunnel0, cmd = 39
class-map match-all server
  match access-group name Web
policy-map POLICE
class server
  police 8000 8000 exceed-action drop class-map match-all server
policy-map POLICE
class server
Advice please for error above
Hi Fahad,
There is another thread that close to your problem you may have a look
https://supportforums.cisco.com/message/3842738#3842738
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
26 Replies 26
Reza Sharifi
What model switch or router?
What is the IOS version?
You want to apply the policy-map on a GRE tunnel interface, right?
Document ID: 10106, "Quality of Service Options on GRE Tunnel Interfaces", explaines how to do that:
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a008017405e.shtml#qosforgretunn
You have to create a nested policy map:
A "parent" map shapes the tunnel interface to give queueing, which is configured in a "child" map, a starting point to recoginze congestion.
Examples can be found in the linked document.
Rolf
Model and version is 3750x 24 SE 12.2(58) SE 2.
interface Tunnel110
description " /\/\/\/\ XX) /\/\/\/\ "
bandwidth 256
ip address 192.168.1.1 255.255.255.252
ip flow ingress
ip tcp adjust-mss 1370
load-interval 30
keepalive 5 3
tunnel source 10.100.100.1
tunnel destination 10.100.100.2
tunnel key 148
int gi1/0/24
no sw port
ip address 10.100.100.1 255.255.255.252
router ospf 1
network 192.168.1.0 0.0.0.3 area 0
policy-map POLICE
class server
policy-map POLICE
class server
police 8000 8000 exceed-action drop.
I have to restrict bandwidth on 256K..pls advice how can i change configuration according to shaping scenerio as per statement above.
Or I can put the same command on giga interface as well by removing tunnel.
I removed tunnels and revised configuration is given below. Now I have to restrict bandwidth to 256K. Pls advice how to limit bandwidth ?
3750x Switch 1:
interface Vlan1
description """Management Vlan"""
ip address 10.50.50.1 255.255.255.0 secondary
ip address 10.10.50.1 255.255.0.0
interface GigabitEthernet1/0/24
description """Branch Network"""
no switchport
bandwidth 256
end
ip route 10.100.100.0 255.255.255.252 10.100.100.2
ip route 172.16.64.0 255.255.255.0 10.100.100.2
ip access-list extended Web
permit ip any any precedence network
policy-map POLICE
class server
  police 256000 8000 exceed-action drop
3750x Switch 2:
interface Loopback100
ip address 172.16.64.10 255.255.255.0
interface GigabitEthernet1/0/10
no switchport
bandwidth 256
ip address 10.100.100.2 255.255.255.252
ip route 10.50.50.0 255.255.255.0 10.100.100.1
ip route 10.100.100.0 255.255.255.252 10.100.100.1
My PC:
Connection-specific DNS Suffix  . :
IPv4 Address. . . . . . . . . . . : 10.50.50.103
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.50.50.1
C:\>ping 172.16.64.10
Pinging 172.16.64.10 with 32 bytes of data:
Reply from 172.16.64.10: bytes=32 time<1ms TTL=254
Any one who has idea, so please comment
Qos is not working, pls respond
Also shape command is not supported on interface level, pls help me out
any one here on forum who suggest
Hi Fahad,
What kind of traffic are you trying to restrict? Or you just want to restrict bandwidth the link connected to Branch network.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Just want to restrict bandwidth
Ok, I see.
Then your above configuration should be ok. But bandwidth command it is for dynamic routing protocol metric calculation. It will not reduce actual bandwidth.
no switchport
end
permit ip any any
policy-map POLICE
class server
For SVI interface you need to use hierarchical policy-map.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/swqos.html#wp1044737
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/swqos.html#wp1767120
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Configuration is ok as per my understanding but bandwidth is not getting restrict, no traffic seen on
Switch#sh policy-map interface gig 1/0/24
  Service-policy input: POLICE
    Class-map: server (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
Advice please...am I doing some wrong
Removed bandwidth command as dynamic protocol not running, pls correct where I am wrong
