Policy routing to two redundant routers.
jkeeffe
Level 2
Level 2
I have a need to policy route some IP addresses and have no problem with how to do that - except when going through a pair of redundant routers.
I need to policy map data from my MVS system through several routers to a WAN router. There are two redundant distribution layer routers in the path, Router-B and Router-C.
On Router-A, right before the two distribution layer routers B & C, I have this route map:
Router-A#
route-map mvs permit 10
match ip address 105
set ip next-hop 164.7x.187.54
164.7x.187.54 is the next hop to Router-B. The next hop from Router-A to Router-C is 164.7x.187.50.
How do I configure the route map on Router-A to route traffic to not only Router-B, but Router-C also in case Router-B fails?
Do I just add a second 'next hop' statement like this?
set ip next-hop 164.7x.187.50
Richard Burts
Jim
I believe that you can put both addresses in the same set command:
set ip next-hop 164.7x.187.54 164.7x.187.50
Rick
Rick
Richard Burts
Jim
Rick
Rick
