Port 49 Failing Scheduled Diagnostic
I have several Catalyst 3850 24- and 48-P-L switches deployed on 3.7(0).  On all of them, I have:
diagnostic schedule switch 1 test non-disruptive daily 0:00 cardindex 4 jobindex 1
diagnostic bootup level complete
diagnostic monitor syslog
On a number of them (not all), I'm getting the message:
Sep  2 00:00:00.511 EDT: %DIAG-3-TEST_FAIL: switch 1: DiagGoldPktTest{ID=1} has failed. Error code = 0x1 (DIAG_FAILURE)
Looking at it further, I'm either getting port 49 failing on a 48-port switch, or port 25 on a 24-port switch.  Any ideas what could be the problem?
weylin
InayathUlla Sharieff
Weylin,
DiagGoldPktTest :
        The GOLD packet Loopback test verifies the MAC level loopback
        functionality. In this test, a GOLD packet, for which doppler
        provides the support in hardware, is sent. The packet loops back
        at MAC level and is matched against the stored packet. It is a non
        -disruptive test.
source:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/system
_management/configuration_guide/b_sm_3se_3850_cg/b_sm_3se_3850_cg_chapter_01101.html
you might be hitting the following bug;0
https://tools.cisco.com/bugsearch/bug/CSCud11268/?reffering_site=dumpcr
Could you please try to upgrade it to 03.03.03SE and update me the result.
Inayath
********please do not forget to rate this post if usefull*********
Thanks Inayath.  I did find that, but that's the extent of what I was able to find on my own.  I'm not sure if I have a configuration error, a hardware fault, or something else.
I tried looking at that URL, and my CCO account doesn't have permission to view that bug.
I'm already on 3.7(0)E, and this doesn't appear to be spurious:
comm1010-393es02#sh ver | i ^Switch|^\*
Switch Ports Model              SW Version        SW Image              Mode
*    1 56    WS-C3850-48P       03.07.00E         cat3k_caa-universalk9 INSTALL
comm1010-393es02#sh diagnostic events switch 1 | e Passed|^08
Diagnostic events (storage for 500 events, 70 events recorded)
Number of events matching above criteria = 70
Event Type (ET): I - Info, W - Warning, E - Error
Time Stamp         ET [Card] Event Message
09/01 02:00:00.854 E  [1]    DiagGoldPktTest Failed
09/01 02:00:01.057 E  [1]    Minor Error Detected
09/02 02:00:00.256 E  [1]    DiagGoldPktTest Failed
09/02 02:00:00.474 E  [1]    Minor Error Detected
09/03 02:00:00.677 E  [1]    DiagGoldPktTest Failed
09/03 02:00:00.914 E  [1]    Minor Error Detected
comm1010-393es02#sh diagnostic result switch 1 failure detail
Current bootup diagnostic level: complete
switch 1:   SerialNo : FOC1912X0KY
  Overall Diagnostic Result for switch 1 : MINOR ERROR
  Diagnostic level at card bootup: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
  ___________________________________________________________________________
    1) DiagGoldPktTest:
   Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
   Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
   Port 49 50 51 52 53 54 55 56
         F  .  .  .  .  .  .  .
          Error code ------------------> 1 (DIAG_FAILURE)
          Total run count -------------> 14
          Last test testing type ------> OnDemand
          Last test execution time ----> Sep 03 2015 02:00:00
          First test failure time -----> Aug 21 2015 02:00:00
          Last test failure time ------> Sep 03 2015 02:00:00
          Last test pass time ---------> n/a
          Total failure count ---------> 14
          Consecutive failure count ---> 14
comm1010-393es02#
To "close the loop" on this thread -
I opened TAC case 680158884.  It's for a different diagnostic test failure, but it's all part-and-parcel the same issue.  The details are in that case, I'd share them here but I'm not sure what is / isn't covered by NDA.
Short version:
The GOLD tests listed as "non-disruptive" are only non-disruptive when ports are in their default configuration.  Therefor, despite what the online documentation says, and despite with the CLI Help (aka "?") says - for any field-deployed / production switch, there's no guarantee of any test being non-disruptive, nor is there a guarantee that a perfectly good port will pass a given test unless in a default configuration.
