Port ACL filters voice and data Vlan !!?
mohammed hashim
hi,
Cisco Document says:
When you apply a port ACL to a port with voice VLAN, the ACL filters traffic on both data and voice VLANs
can someone please give me an example of this?
I did not find any good example or topology explain this
thanks,
Austin Sabio
Level 4
Level 4
  • Port ACLs are similar to Router ACLs but are supported on physical interfaces and configured on Layer 2 interfaces on a switch. Port ACL supports only inbound traffic filtering. Port ACL can be configured as three type access lists: standard, extended, and MAC-extended.
  • Processing of the Port ACL is similar to that of the Router ACLs; the switch examines ACLs associated with features configured on a given interface and permits or denies packet forwarding based on packet-matching criteria in the ACL.
  • When applied to a trunk port, the ACL filters traffic on all VLANs present on the trunk port. When applied to a port with voice VLAN, the ACL filters traffic on both data and voice VLANs.
  • The main benefit with Port ACL is that it can filter IP traffic (using IP access lists) and non-IP traffic (using MAC access list). Both types of filtering can be achieved—that is, a Layer 2 interface can have both an IP access list and a MAC access list applied to it at the same time.
  • NOTE Port ACLs are not supported on EtherChannel interfaces.
Switch(config)# interface vlan 20
Switch(config-if)# description data_vlan
Switch(config-if)# ip address 192.168.20.1 255.255.255.0
Switch(config)# interface vlan 120
Switch(config-if)# description voip_vlan
Switch(config-if)# ip address 192.168.120.1 255.255.255.0
Switch(config)# ip access-list extended NO-ICMP
Switch(config-ext-nacl)# deny icmp host 192.168.50.1 any
Switch(config-ext-nacl)# permit ip any any
switch(config)# interface gigabitEthernet 1/0/1
switch(config-if)# switchport mode access
switch(config-if)# switchport access vlan 20 ---------------(workstation)
switch(config-if)# switchport voice vlan 120 ---------------(voip_phone)
Switch(config-if)# ip access-group NO-ICMP in
This means host 192.168.50.1 will be denied from reaching both clients workstation+voip_phone (data and voice) that are connected to interface Gi1/0/1 by NO-ICMP ACL. NO-ICMP ACL is applied on int Gi1/0/1 for both traffics ---data and voice.
For complete review see: https://www.youtube.com/watch?v=YsSmx9TsH7Y
Please rate, if helpful.
Thank you.
hi, thanks for reply.
but usually the IP phone has different IP than the Computer, when you filter IP 192.168.50.1 inbound, it only will filter that IP,
means if 192.168.50.1 was the PC IP, then the phone could have 192.168.50.2
this is what I understood from your configuration,
also the video on youtube does not cover this as I saw the topology explanation part
