Port aggregation
Kirillg88
Community Member
Hi guys. Need a little help with configuration. I'll describe my CURRENT config :
1st communication room Stack of
MS225-48 port 49 uplink port from master
MS225-24 port 25 uplink from slave
PORT 52 and PORT 28 aggregated
2nd room
MS225-48 port 51,52 aggregated
51 going to port 28 (1st communication room)
52 going to port 52 (1st communication room)
I'm about to add another MS225-24 to 2nd room (Will be stack with MS225-48)
Now the question is how im doing the aggregation correctly after i'll add another switch
NOTE: I have only 2 optic cables coming from 1st communication room to 2nd
Hope i was clear. Thanks !
AjitKumar
Level 10
Level 10
Hi @Kirillg88
With my Limited Knowledge I can think of following Connectivity.
May be @kYutobi can suggest mistakes in this diagram.
Ajit
[email protected]
www.ajit.network
10 Replies 10
kYutobi
Level 11
Level 11
If my understanding is correct you're just adding another switch to the 2nd room. Wouldn't you just uplink the new switch from the MS225-48 port 51,52 aggregated? It's already set unless you're doing something different.
Enthusiast
Yes , im just adding another switch and i'll make a stack of 2 switches . How should i uplink the new switch from the MS225-48 port 51,52 aggregated if both of them connected to aggregated ports in 1st server room. Should i take 1 link to the new switch ? Then aggregate ports on the new switch and connect to 1st room ?
For example :
2nd room
MS225-48 port 51,52 aggregated port 51 to port 27 , port 52 to MS225-48 port 52 (1st room)
MS225-24 port 27,28 aggregated port 28 to MS225-24 port 28 (1st room)
Here's an example. You don't need to have 2 cables on 24 port switch lol I added just because.
Enthusiast
AjitKumar
Level 10
Level 10
Hi @Kirillg88
Ajit
[email protected]
www.ajit.network
@AjitKumar wrote:
Hi @Kirillg88
Thats exactly how i thought to do it , but wasnt sure if it's the right way
That way is correct for redundancy. I just wasn't sure if you wanted to change your current config. @AjitKumar thanks. @Kirillg88 wasn't sure if you were going to stack the switches together in 2nd room which I should've asked.
Enthusiast
Yes , i have mentioned that im going to stack them 😉
@Kirillg88 Oh my! I did read over it. 😔 So sorry. Thanks again @AjitKumar😁
Enthusiast
Thats ok, thanks a lot anyway 🙂
Juanf574
Community Member
on another note:
I just go a new MS225 switch and created a port aggragate group. does anyone know how to undo do it?
thank you
