Port already in a port-channel
Rem Markov
Hey everyone!
I have a N9K c9372PX with FEX N2K-C2232PP-10GE.
In Eth101/1/1 I have previously configured channel-group and access vlan.
When trying to default the interface I recieve:
ERROR: port already in a port-channel, no config allowed.
The only has one setting to it:
switchport access vlan 123
The main problem is that there is no Port-channel associated with this interface and the previous port-channel is deleted.
(Trying to recreate the PO didn't help)
I assume it a bug? Because all the workaround didn't help nor matched the case.
Rem Markov
It was solved!
Finally It tried looking at port-channel summery, and I have seen a port-channel with the interface in it. even though he was never part of it.
After deleting the port-channel everything worked.
5 Replies 5
There is force mode in port channel in nexus
This mode make all ports member use same config that port channel use.
You need to shut the port channel first then try defualt this port
MHM
There is no Port-Channel associated with the interface
And the one that was is non-existent now
But I really don't want to factory reset the whole FEX. Just this one interface.
Rem Markov
It was solved!
