Port assignments
Ayman Elkady
     Dear all,
i hope you do help me in this
i do have an audio device that is forwarding multicast traffic to other speakers on ethernet network , they are all in same vlan same switch .
i was wondering can i program that if i connected certain device with certain MAC address (MIC) that traffic flows from this mic to a  specified speakers port , and preventing the multicast traffic to pass throgh these speaker ports . but not to prevent other multicast to pass to other ports .
it is a bit complicated
but can i do it with VACL and PACL , since this is a layer2 traffic as well .
another question is can i capture a traffic from a port on the switch and broadcast it to all ports or multicast it .
alam
Is it possible to assign different multicast address to partition different mic and speaker?
Hello
not really sure of.your requst as it isnt that clear to me however enabling mc.on a single switch isnt required as igmp snooping is usually enable by default which wlll control.the distribution.of mc traffiic on that device
to only the hosts that want to receive mc.
you can also specify a specific vlan for igmp to.run on
ip igmp snooping vlan xxx
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
alam
yes it will be possible
Hello
Please review this cco doc
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfssm.html
http://ciscomulticast.blogspot.co.uk/2011/11/cisco-ssmsource-specific-multicast.html
Res
Paul
Kind Regards
Paul
