Port base authentication 802.1X
techguy
Level 4
Level 4
I am configuring Port base authentication on Cisco catalyst 2960X switch. But i am getting following error while i connect laptop on this port and getting no ip address. Dot1X status is fialed over.
Nov 22 08:09:54.270: %AUTHMGR-5-START: Starting 'dot1x' for client (6431.500e.7679) on Interface Gi1/0/45 AuditSessionID 0A01D08F000045A50EC87CAE
Nov 22 08:11:26.629: %DOT1X-5-FAIL: Authentication failed for client (6431.500e.7679) on Interface Gi1/0/45 AuditSessionID 0A01D08F000045A50EC87CAE
Nov 22 08:11:26.629: %AUTHMGR-7-RESULT: Authentication result 'no-response' from 'dot1x' for client (6431.500e.7679) on Interface Gi1/0/45 AuditSessionID 0A01D08F000045A50EC87CAE
Nov 22 08:11:26.629: %AUTHMGR-7-FAILOVER: Failing over from 'dot1x' for client (6431.500e.7679) on Interface Gi1/0/45 AuditSessionID 0A01D08F000045A50EC87CAE
Nov 22 08:11:26.629: %AUTHMGR-7-NOMOREMETHODS: Exhausted all authentication methods for client (6431.500e.7679) on Interface Gi1/0/45 AuditSessionID 0A01D08F000045A50EC87CAE
Nov 22 08:11:26.629: %AUTHMGR-5-FAIL: Authorization failed or unapplied for client (6431.500e.7679) on Interface Gi1/0/45 AuditSessionID 0A01D08F000045A50EC87CAE
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
dot1x system-auth-control
interface GigabitEthernet1/0/45
switchport access vlan 1
switchport mode access
switchport voice vlan 2
authentication port-control auto
dot1x pae authenticator
spanning-tree portfast
radius server test
address ipv4 10.1.208.70 auth-port 1812 acct-port 1813
key 7 123456789
Ganesh Hariharan
Hello ,
What error mesage are you seeing on radius server while tryng to authenticate.
-GI
