port-based address allocation
aviyoshi10
Level 3
Level 3
can i eanble this feature on etherchannel interface ?
i have single server with 2 X NIC (teaming LACP) towards the switch.
thanks,
Avi.
5 Replies 5
Reza Sharifi
When you team the NICs together, they logically become one interface.  So DHCP will assign one IP to both interfaces.
aviyoshi10
Level 3
Level 3
Ok
Do i need to configure something special?
When i connect the server with single interface it works.
With teaming it doesn't
On the server side you need to configure NIC teaming with LACP (passive).  On the switch side you need to configure the Etherchannel with LACP (active).  Can you post the config from the switch?
yes please do,
also see the debugging messages.
relevant config:
ip dhcp use subscriber-id client-id
ip dhcp subscriber-id interface-name
ip dhcp pool VLAN120
   network 181.120.0.0 255.255.0.0
   default-router 181.120.0.254
   dns-server 181.120.0.254
   reserved-only
   address 181.120.10.1 client-id "Fa1/0/1" ascii
   address 181.120.10.111 client-id "Fa1/0/2" ascii
   address 181.120.10.99 client-id "Po1" ascii
   address 181.120.10.88 client-id "Fa2/0/2" ascii
   address 181.120.0.77 client-id "Fa2/0/15" ascii
   address 181.120.0.55 client-id "Fa2/0/23" ascii
   address 181.120.10.95 client-id "Po2" ascii
   address 181.120.10.94 client-id "Port-channel2" ascii
port-channel load-balance dst-mac
interface Port-channel2
switchport access vlan 120
switchport mode access
ip dhcp server use subscriber-id client-id
ip dhcp client client-id Port-channel2
spanning-tree portfas
interface FastEthernet2/0/8
channel-protocol lacp
channel-group 2 mode active
spanning-tree portfast
interface FastEthernet2/0/9
Switch#sh inter port-channel 2 etherchannel
Port-channel2   (Primary aggregator)
Age of the Port-channel   = 0d:02h:37m:51s
Logical slot/port   = 10/2          Number of ports = 2
HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =   LACP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Fa2/0/8  Active             0
  0     00     Fa2/0/9  Active             0
Debug:
03:44:23: DHCPD: Reload workspace interface Vlan120 tableid 0.
03:44:23: DHCPD: tableid for 181.120.0.254 on Vlan120 is 0
03:44:23: DHCPD: client's VPN is .
03:44:23: DHCPD: using subscriber-id as client-id
03:44:23: DHCPD: using received relay info.
03:44:23: DHCPD: Sending notification of DISCOVER:
03:44:23:   DHCPD: htype 1 chaddr 0004.23e1.b7dc
03:44:23:   DHCPD: interface = Vlan120
03:44:23:   DHCPD: class id 4d53465420352e30
03:44:23: DHCPD: DHCPDISCOVER received from client 4661.322f.302f.39 on interface Vlan120.
03:44:23:   DHCPD: htype 1 chaddr 0004.23e1.b7dc................intreface mac-address of teaming
03:44:23: DHCPD: requested address 169.254.210.64 is not on subnet 181.120.0.0.
03:44:23: DHCPD: Allocate an address without class information (181.120.0.0)
03:44:26: DHCPD: Reload workspace interface Vlan120 tableid 0.
03:44:26: DHCPD: tableid for 181.120.0.254 on Vlan120 is 0
03:44:26: DHCPD: client's VPN is .
03:44:26: DHCPD: using subscriber-id as client-id
03:44:26: DHCPD: using received relay info.
03:44:26: DHCPD: Sending notification of DISCOVER:
03:44:26:   DHCPD: htype 1 chaddr 0004.23e1.b7dc
03:44:26:   DHCPD: interface = Vlan120
03:44:26:   DHCPD: class id 4d53465420352e30
03:44:26: DHCPD: DHCPDISCOVER received from client 4661.322f.302f.39 on interface Vlan120.
03:44:26: DHCPD: requested address 169.254.210.64 is not on subnet 181.120.0.0.
03:44:26: DHCPD: Allocate an address without class information (181.120.0.0)
03:44:33: DHCP_SNOOPING: checking expired snoop binding entries
03:44:35: DHCPD: Reload workspace interface Vlan120 tableid 0.
03:44:35: DHCPD: tableid for 181.120.0.254 on Vlan120 is 0
03:44:35: DHCPD: client's VPN is .
03:44:35: DHCPD: using subscriber-id as client-id
03:44:35: DHCPD: using received relay info.
03:44:35: DHCPD: Sending notification of DISCOVER:
03:44:35:   DHCPD: htype 1 chaddr 0004.23e1.b7dc
03:44:35:   DHCPD: interface = Vlan120
03:44:35:   DHCPD: class id 4d53465420352e30
HI,
what do you think?
