Rate Limit and QoS
Braunimus
I am having an issue with VoiP phones giving me an insufficient bandwidth message.  I have three remote locations connected to our main building using 2 Mb point to point ethernet solutions through TWC.  Each remote location has a Cisco WS-C3560-24PS running IOS C3560-IPBASE-M, version 12.2(25) and have the cable modems plugged into port 1 on them.  The remote buildings are labeled 192.168.101.xxx, 192.168.102.xxx, and 192.168.103.xxx.  There are 14-16 VoiP phones in each remote building.  The main building being in the subnet of 192.168.100.xxx.  I have the 3560s connecting to a single port on a 2801 in the main building, all using the subnet of 192.168.253.xxx  The phone server sits in our network at 192.168.100.203.  I have created the ACLs, class maps, and policy maps on all of the equipment.
For the remote buildings I have the following:
ACL
Extended IP access list VOIP
permit tcp any host 192.168.100.203 dscp ef
permit tcp any host 192.168.100.203 eq 5566
permit tcp any host 192.168.100.203 eq 5570
permit tcp any host 192.168.100.203 range 3998 3999
permit tcp any host 192.168.100.203 range 6800 6802
permit udp any host 192.168.100.203 dscp ef
permit udp any host 192.168.100.203 eq 5566
permit udp any host 192.168.100.203 eq 5567
permit udp any host 192.168.100.203 eq 20001
permit udp any host 192.168.100.203 range bootps tftp
permit udp any host 192.168.100.203 range 5004 5064
permit udp any host 192.168.100.203 range 6004 7039
permit ip any host 192.168.100.203 dscp ef
permit ip any any dscp ef
Extended IP access list DEFAULT
permit ip any any
Class Map
class-map match-any VOIP
  match access-group name VOIP
class-map match-any DEFAULT
  match access-group name DEFAULT
Policy-Map
policy-map PER-PORT-POLICING
  class VOIP
   set dscp ef
    police 128000 8000 exceed-action drop
  class DEFAULT
   set dscp default
I have the policy map applied to all ports with PCs and VoiP phones connected to them.  Here is what I have on the ports fa0/2 - 24
interface FastEthernet0/2
switchport access vlan 101
switchport mode access
service-policy input PER-PORT-POLICING
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
priority-queue out
spanning-tree portfast
Here is the setup on the interface connected to TWC
interface FastEthernet0/1
description "Connection to Time Warner BCE"
no switchport
ip address 192.168.253.101 255.255.255.0
speed 10
duplex full
srr-queue bandwidth limit 20
priority-queue out
mls qos trust dscp
auto qos voip trust
The 2801 in the main building is running IOS C2801IPBASE-M, version 12.3(8).  Here are the settings I have applied on it:
ACL
access-list 101 permit ip any 192.168.101.0 0.0.0.255
access-list 102 permit ip any 192.168.102.0 0.0.0.255
access-list 103 permit ip any 192.168.103.0 0.0.0.255
ip access-list extended VOIP
remark "Phone System ports"
permit tcp host 192.168.100.203 any dscp ef
permit tcp host 192.168.100.203 eq 5566 any
permit tcp host 192.168.100.203 eq 5570 any
permit tcp host 192.168.100.203 range 3998 3999 any
permit tcp host 192.168.100.203 range 6800 6802 any
permit udp host 192.168.100.203 any dscp ef
permit udp host 192.168.100.203 eq 5566 any
permit udp host 192.168.100.203 eq 5567 any
permit udp host 192.168.100.203 eq 20001 any
permit udp host 192.168.100.203 range bootps tftp any
permit udp host 192.168.100.203 range 5004 5064 any
permit udp host 192.168.100.203 range 6004 7039 any
permit ip host 192.168.100.203 any dscp ef
ip access-list extended DEFAULT
permit ip any any
Class Map
Policy Map
policy-map WAN-POLICING
class VOIP
  set dscp ef
  priority 1536
class DEFAULT
  set dscp default
ip address 192.168.253.100 255.255.255.0
service-policy output WAN-POLICING
speed 100
duplex full
rate-limit output access-group 101 2048000 64000 96000 conform-action transmit exceed-action drop
rate-limit output access-group 102 2048000 64000 96000 conform-action transmit exceed-action drop
rate-limit output access-group 103 2048000 64000 96000 conform-action transmit exceed-action drop
I have put a hub in to capture traffic via Wireshark to see if DSCP flags are being appropriately marked and I do see that all VoiP packets are getting marked with as EF.  However, I have been receiving phone calls from people in the remote buildings stating that their phones will cut out, flash Insufficient Bandwidth on the LCD displays and then the call will cut back in.  I am wondering if the 2801 is not applying QoS with the rate-limits in mind since it is set to 100 Mb, or is it an issue with trying to take 3 remote locations and bring them down into 1 port on the 2801?
6 Replies 6
rowseyba1
Mark,
I may just be missing it, but I don't actually see where you applied your policy map on the out going interface of your WAN device on the first TWC connection.  Also, have you confirmed that you aren't exceeding the BW on those links? Also, is TWC honoring your QoS marks on the point to point?  What kind of VoIP phones are they?
The TWC connection is plugged into FastEthernet0/1 on the Cisco 3560 which will not allow me to put a service-policy on the outbound traffic.  It will only allow me to apply it to input.  So I was using the service-policy input on ports 2 - 24 to mark and limit the traffic for each user.  I do have a NAGIOS monitoring system setup and I will get emails from it stating ping time is rather high at times (<200ms) and when I login to the 3560 I can see the traffic going out is usually over 1.7 Mb/sec.  To check if TWC is not changing my packets I put a hub in on each of the lines and have used wireshark to capture the packets and look at them to make sure all of my markings are still there and they indeed are.  We are using Mitel phones model number 8662.
Can you match the problem to those times of high utilization or does it happen randomly even if you aren't using all of your bandwidth?
The reason I ask is I have run into a situation where not being able to have QoS on both sides of the circuit has caused quality issues when BW utilization is high.  Once we were able to put a service policy on both sides of the connection, it got better, but we still ended up having to increase the bandwidth a bit to compensate fully.
Edit:  I did some research on your Insufficient Bandwidth message on the Mitel phones.  It seems this may have something to do with latency on the network as well.  The posts that I saw said something about the phone having to receive 60% of frames in a certain amount of time.  If you google "mitel insufficient bandwidth"  the first article will explain further.
Sorry it has taken me a while to respond.  I have noticed that it is not always when bandwidth is high.  I do have NAGIOS deployed and checking ping times on the end points to see if the latency reaches over 100ms and sometimes when there are phone issues the latency does get high.  This also usually correlates to high utilization on the line.  I did just have an issue today where latench was <20ms, and we were only using tops of 25% of the bandwidth.  Phones worked for some while data applications from the PCs didn't and vica versa.  I am beginning to think I am crazy.
The phone system was put in by another company and I am going to get on the phone with them to see if maybe they can help point me in a good direction to see if I can get this resolved.  I do have a service policy applied outward on the Cisco 2801, but I am unable to apply an output policy on the Cisco 3560 interfaces.  Reading the Cisco documentation has pointed me in the direction of applying a service policy to the input side of the client facing interfaces and letting srr-queue and priority-queue out handle pushing and prioritizing traffic on the WAN facing interface.
If I were you I would do the following
1- before I get the phone company involved. I would findout where the latency happning
     a- start with both ends of the ciruits directly on the router interface and see if you have any latency.
     b- remove all your bandwidth rate limiting and see if you still getting the bandwidth error on the phones.
     c- find out if this happen on active calls or when the phones are ideal.
     d- if on active calls, was it G711 or G729 call, was it a conf call, transfered call, or direct call.
     e- do you have a way to monitor latency on the Metro E?
then I go to the phone company
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
LAN switches, like the 3560s, are not ideal for precise QoS.  At-a-glance, your remote 3560 configs looks okay although do be aware the interface limiter isn't exact.  I.e. your 20% for the 10 Mbps could be higher.
On your HQ side, try a policy similar to:
class-map match-any Site1
match access-group 101
class-map match-any Site2
match access-group 102
class-map match-any Site3
match access-group 103
policy-map WAN-QoS
class VOIP
  set dscp ef
  priority percent 50
class class-default
  set dscp default
  fair-queue
policy-map WAN-Parent
class Site1
  shape average 1800000
  service-policy WAN-QoS
class Site2
class Site3
service-policy output WAN-Parent
!remote the rate-limiters
