Port-channel b/w Nexus5k and 9300 will not come up
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-25-2025 01:55 AM
hi Experts,
one end is N5K-C5672UP-16G with version 7.3(0)N1 and the other end is C9300-48T with Version 17.6.4
I am trying to create portchannel between the devices which are like less than 1km far away. and separated via dark fiber.
On 9300 end, i connected SFP-10GBase-LR
INHYDPALABSW05#show interfaces status | in LR
Te1/1/7 UPLINK TO INHYDPA_ notconnect 1 full 10G SFP-10GBase-LR
Te2/1/7 UPLINK TO INHYDPA_ notconnect 1 full 10G SFP-10GBase-LR
interface TenGigabitEthernet1/1/7
description UPLINK TO INHYDPA_9500_VSS
switchport trunk allowed vlan 20,61-93,151,609,610,712,714,751-755,800-803
switchport mode trunk
channel-group 3 mode active
end
interface TenGigabitEthernet2/1/7
interface Port-channel3
duplex full
INHYDPALABSW05#show interfaces po3
Port-channel3 is down, line protocol is down (notconnect)
Hardware is EtherChannel, address is 0000.0000.0000 (bia 0000.0000.0000)
Description: UPLINK TO INHYDPA_9500_VSS
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is N/A
input flow-control is on, output flow-control is unsupported
Nexus1 end
INHYDPANexus01# show interface status | in LR
Eth1/2 UPLINK TO INHYDPAL notconnec trunk full 10G 10Gbase-LR
INHYDPANexus02# show interface status | in LR
!Command: show running-config interface Ethernet1/2
!Time: Mon Apr 13 23:49:23 2009
version 7.3(0)N1(1)
description UPLINK TO INHYDPALABSW05
switchport trunk allowed vlan 20,61-93,151,609-610,712,714,751-755,800-803
duplex full
channel-group 34 mode active
INHYDPANexus02# show run int po34
!Command: show running-config interface port-channel34
!Time: Mon Apr 13 23:49:26 2009
version 7.3(0)N1(1)
speed 10000
duplex full
duplex full
INHYDPANexus01# show run int Po34
!Time: Mon Apr 13 23:47:22 2009
version 7.3(0)N1(1)
speed 10000
duplex full
INHYDPANexus01#
When i connect the SFP, i get a message saying "%ETHPORT-5-IF_HARDWARE: Interface Ethernet1/2, hardware type changed to No-Transceiver"
When i use the SFP using two ports on the same device to test if the SFPs are working fine, then the ports come up. but when i try to connect b/w two buildings the ports do not come up.
There are two device connected via dard fiber. WS-C3650-48TD and C9300-48T using 1000BaseLX and the connection is up via the same dark fiber.
First i though the cable might be faulty, so i used the cable from the link which is working fine, but still the link will not come up.
Ethernet1/2
transceiver is present
type is 10Gbase-LR
name is CISCO-ACCELINK
part number is RTXM228-401-C88
revision is 1.0
serial number is ACW28110Y6Z
nominal bitrate is 10300 MBit/sec
Link length supported for 9/125um fiber is 10 km
cisco id is --
cisco extended id number is 4
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 34.20 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.34 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 30.45 mA 75.00 mA 15.00 mA 70.00 mA 18.00 mA
Tx Power -2.34 dBm 3.49 dBm -12.21 dBm 0.49 dBm -8.21 dBm
Rx Power N/A -- 3.49 dBm -18.53 dBm 0.49 dBm -14.43 dBm
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
INHYDPALABSW05#show interfaces tenGigabitEthernet 1/1/7 transceiver detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te1/1/7 32.0 75.0 70.0 0.0 -5.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te1/1/7 3.30 3.63 3.46 3.13 2.97
Current Threshold Threshold Threshold Threshold
Port Lane (milliamperes) (mA) (mA) (mA) (mA)
Te1/1/7 N/A 39.0 75.0 70.0 18.0 15.0
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port Lane (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/1/7 N/A -2.6 3.5 0.5 -8.2 -12.2
Receive Power Threshold Threshold Threshold Threshold
Te1/1/7 N/A -40.0 3.5 0.5 -14.1 -18.4
- Labels:
LAN Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-25-2025 01:57 AM
Please suggest what can be done to bring the link up. and specially "Interface Ethernet1/2, hardware type changed to No-Transceiver"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-25-2025 03:35 AM
- @shallu.garg27 >... and the connection is up via the same dark fiber.
>...so i used the cable from the link which is working fine
- It remains a bit doubtful; you should always have a fiber link quality test on the dark fiber link and check if
it is conformal with specs. That test should be done with fiber testing equipment; not with the switches.
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-25-2025 09:05 AM
There are many reason
1-First try enable FEC in both sides
2- do show port-channel summary<<- check if port is suspended
3- do show spanning tree <<- check if port is BLK or error
MHM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-26-2025 09:24 PM
one side in Nexus5k and the other side 9300 switch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-26-2025 09:25 PM
34 Po34(SD) Eth LACP Eth1/2(D)
35 Po35(SD) Eth LACP Eth1/22(D)
Interfaces are down, not showing in spanning tree on both sides
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-26-2025 10:08 PM
i am using 10G on both sides, and command to enable FEC is not coming ..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-26-2025 09:30 PM
INHYDPANexus01# show interface Eth1/2 transceiver
Ethernet1/2
type is 10Gbase-LR
revision is 1.0
cisco id is --
INHYDPALABSW06#sh inventory | in LR
NAME: "Te1/1/7", DESCR: "SFP-10GBase-LR"
PID: SFP-10G-LR-S , VID: V01 , SN: ACW28110Y7Z
NAME: "Te2/1/7", DESCR: "SFP-10GBase-LR"
PID: SFP-10G-LR-S , VID: V01 , SN: ACW28110Y8C
INHYDPALABSW06#
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-26-2025 09:41 PM
Can we start with the basics first: Remove the etherchannel config.
With the etherchannel config removed, are each of the individual links up?
