Port-Channel between 40gig and 10Gig interfaces
Nehadeepu
I want to configure the port-channel between 49Gig and 10Gibs. One side is a Cisco 3850 with 40gig interfaces and remote end is a Cisco4500X with SPF + interface. Can we set up EtherChannel between the two switches?
marce1000
 - Only  , if the individual ports on  the 3850 can auto-downgrade-negotiate to 10g (you can't expect the 4500 to become suddenly 40g-capable).
 M.
Deepak Kumar
Check the capabilities details as:
sho interfaces fortyGigabitEthernet 1/1/1 capabilities
FortyGigabitEthernet1/1/1
Model: WS-C3850-48XS
Type: unknown
Speed: 10,100,1000,auto
Duplex: full,half,auto
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(2p6q3t)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
If you will find the details as highlighted (Speed and Duplex) then it will work.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
