Port-Channel between 4507
rc5295509
Hello
I have a doubt..
I need to configure a port channel between two sw 4507R. with port Giga, but those port are in different modules.
Sw-1
interface GigabitEthernet5/48
description **** Conexion Switch-2*****
switchport mode trunk
duplex full
service-policy input servicios
service-policy output servicios
interface GigabitEthernet4/5
SW-2
interface GigabitEthernet3/5
description **** Conexion Switch-1*****
logging event link-status
interface GigabitEthernet5/24
You see the "service-policy input servicios".  Qos is suported in a port channel in sw 4507?  this is my doubt. actualy, the port 5/24 is blocked by stp, and I want to configure port channel... the version is 12.1.(19)EW1
Well, Thanks for your wise answer
Reza Sharifi
You need to add these interfaces to the Etherchannel
example:
channel-group x mode active
rmfalconer
Before adding the interfaces to etherchannel configuration with the above commands, you need to create the port channel interfaces:
interface Port-Channelx
Then use the above commands on each of the physical interfaces.
