Port channel between C8200-1N-4T and
akshaycjoshi
2 interfaces on C8200-1N-4T:
GigabitEthernet0/0/0
GigabitEthernet0/0/1
need to form a port channel with 2 interfaces on C9500-16X:
Te1/0/1
Te1/0/2
On the router side, it has to be L3 port channel and on the switch side it has to be L2.
Can someone please help me with config.
8 Replies 8
akshaycjoshi
I want to add here that the router is in controller mode
Follow below guide on Router with Sub-interface tagging with VLAN,
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/ios-xe-17/systems-interfaces-book-xe-sdwan/m-cisco-sd-wan-etherchannel.html
On the switch it will be Layer 2 Port-channel (allow VLAN in the port-channel)
Create a VLAN on switch and create SVI associate with Layer2 VLAN for them to work.
BB
Router(config)# interface GigabitEthernet0/0/0
Router(config-if)# no shutdown
Router(config-if)# no negotiation auto
Router(config-if)# channel-group 1 mode active
Router(config-if)# lacp rate fast
Router(config-if)# exit
Router(config)# interface GigabitEthernet0/1/1
Router(config)# interface Port-channel1
Router(config-if)# ip address 3.0.0.1 255.255.255.0
Router(config)# commit
Aborted: inconsistent value: Device refused one or more commands:
% Invalid input detected at '^' marker."
Router(config)#
some how not liking that command - are you copy and pasting or configuring directly on cli ?
I have not encountered that error before
lets try 2 different ways :
1. create port-channel and ports later to port-channel
2. 0/1/1 (is the module or NIM card ?)
3. add only 0/0/0 and commit.
BB
This command use only for port members not for PO
So config PO add IP to it
In SW config same but don't add any IP to PO
MHM
Thanks MHM for your reply.
I have already given the interface names, can you please provide me the final config.
THIS QUESTION IS STILL NOT ANSWERED. Please let me know if someone can answer it.
gary-gatten
Old thread - but did you get this resolved?  You have a few different options, assuming you found one that worked for you?
