Port-Channel Interface Configuration EtherChannel and LACP in same Port-Channel
lukesmith0788
I currently have two links which form a Port-Channel from 1 cisco device to another.
I want to change the port-channel config from
channel-group 1 mode on
to
channel-group 1 mode active
So that the Port-Channel is now running LACP, so I can also turn on lacp rate fast
To prevent any outage I was going to shut 1 of the interfaces in the Port-Channel change to LACP and rejoin the port-channel, but I was wondering is it possible to have 1 link running "on" and 1 link running "active" LACP in the same Port-Channel.
Any advice would be appreciated.
Luke
Mark Malone
I would think the links will go standalone in etherchannel , be careful not to cause a loop
on mode uses no protocol so it wont mix with lacp and form a channel as it wont understand the negotiation
