Port-channel issues between Cisco Business 220 and Cisco 9500
jalushi
Hello everyone,
Has anyone configured a port-channel between the 2 types of switches in the title and has had issues such as disconnects and high ping times?
I have tried a couple of solutions such as disabling back-pressure and enabling flow control, however there are still occasional disconnects from the two switches while in port-channel connection.
Thank you for any information.
It then cbs220 bug issue.
Dont waste your time,
Check about bug in PO in cbs220
Good luck
MHM
6 Replies 6
Let see
Show ether channel summary
From c9500 side
Let check health of PO
MHM
Health of PO is fine, showing as in use and both ports are bundled in port-channel.
The mode is ON or LACP active?
Mode is LACP
Good luck
MHM
I thought that as well, since the 9500 works fine with other switches, it's only this one that gives me issues.
