Showing results forĀ
Search instead forĀ
Did you mean:Ā
BUILT-IN-EPA-8x1G
amagboo
can BUILT-IN-EPA-8x1G on Cisco ASR 1002 HX support 10Mbps?
pieterh
on a router in this class, I can't find any reason why you would want to run the port at 10Mbps!
specs don't mention anything about multispeed , not even 100Mbps
-> 1G = 1G only
however there is an module that has 10/100M capabilities,
Cisco 4-Port 10BASE-T/100BASE Fast Ethernet Shared Port Adapter, V-2
SPA-4X1FE-TX-V2
Cisco 8-Port 10BASE-T/100BASE Fast Ethernet Shared Port Adapter, V-2
SPA-8X1FE-TX-V2
but no such info about the  BUILT-IN-EPA-8x1G
pieterh
-> 1G = 1G only
SPA-4X1FE-TX-V2
SPA-8X1FE-TX-V2
balaji.bandi
is this SFP module right - if you install GLC-T should support 10MB
also check installation guide :
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/1001HX_1002HX/b_ASR1001HX-1002HX_HIG/b_ASR1001HX-1002HX_HIG_chapter_01.html
BB
