Port channel(MEC) issue with HP procurve
mateens
I have a pair of cisco 9407R in stackwise virtual. Trying to do multi chasis port channel using lacp with HP pro curve 5412zl. Port channel stays active for few sec and then goes is in err-disable state.
Gi 1/6/0/37 & Gi 2/6/0/37 on Cisco are connected to C23 & C24 on HP.
HP config:
SW-A:
interface C23
lacp active
interface C24
lacp active
trunk C23-C24 trk1 lacp
vlan 140 tagged trk1
vlan 1 untagged trk1
Cisco config:
vlan 140
name mgmt
int vlan 140
ip address xxxxxxxxxxxxxx
SW1
interface GigabitEthernet 1/6/0/37
switchport mode trunk
channel-group 1 mode active
interface GigabitEthernet 2/6/0/37
Logs from Hp
0139:13:48:53.36 lacp mLACPCtrl:LACP: Port C23 is UP
0139:13:48:53.36 lacp mLACPCtrl:LACP: LACP data BPDU Tx on port C23
I 12/18/18 13:08:07 00435 ports: port C23 is Blocked by LACP
0139:13:48:53.44 lacp mLACPCtrl:LACP: Port C24 is UP
0139:13:48:53.44 lacp mLACPCtrl:LACP: LACP data BPDU Tx on port C24
I 12/18/18 13:08:07 00435 ports: port C24 is Blocked by LACP
0139:13:48:54.34 lacp mLACPCtrl:LACP: LACP data BPDU Tx on port C23
0139:13:48:54.34 lacp mLACPCtrl:LACP: Periodic timer has been set to
   FAST_PERIODIC_TIME for port C23
0139:13:48:56.18 lacp mLACPCtrl:Manual LACP: Partner info selected for port
   C24,partner port 3622,partner system-priority 32768,partner port priority
   32768,partner Key 3622
0139:13:48:56.18 lacp mLACPCtrl:Manual LACP: Err: Port C23 is blocked due to
   partner info mismatch
0139:13:48:56.18 lacp mLACPCtrl:Manual LACP: System ID 4509ae8 and Port key 1
   are matched for port C24
0139:13:48:56.18 lacp mLACPCtrl:LACP: LACP data BPDU Tx on port C24
I 12/18/18 13:08:10 00078 ports: trunk Trk1 is now active
I 12/18/18 13:08:10 00435 ports: port C24 is Blocked by STP
0139:13:48:56.21 lacp mLACPCtrl:LACP: Data BPDU Rx. on port C23
0139:13:48:56.21 lacp mLACPCtrl:Manual LACP: Partner info selected for port
   C23,partner port 5670,partner system-priority 32768,partner port priority
   32768,partner Key 5670
0139:13:48:56.21 lacp mLACPCtrl:LACP: LACP data BPDU Tx on port C23
I 12/18/18 13:08:10 00435 ports: port C23 is Blocked by STP
0139:13:48:56.34 lacp mLACPCtrl:LACP: LACP data BPDU Tx on port C23
0139:13:48:56.34 lacp mLACPCtrl:LACP: Periodic timer has been set to
0139:13:48:56.34 lacp mLACPCtrl:LACP: LACP data BPDU Tx on port C24
   FAST_PERIODIC_TIME for port C24
0139:13:48:58.34 lacp mLACPCtrl:LACP: Periodic timer has been set to
   SLOW_PERIODIC_TIME for port C24
I 12/18/18 13:08:13 00076 ports: port C23 in Trk1 is now on-line
I 12/18/18 13:08:13 00076 ports: port C24 in Trk1 is now on-line
0139:13:50:14.16 lacp mLACPCtrl:Manual LACP: System ID 4509d08 and Port key 1
   are matched for port C23
0139:13:50:14.16 lacp mLACPCtrl:Manual LACP: Partner info selected for port
0139:13:50:14.16 lacp mLACPCtrl:Manual LACP: System ID 4509ae8 and Port key 1
0139:13:50:14.16 lacp mLACPCtrl:LACP: LACP data BPDU Tx on port C24
0139:13:50:14.17 lacp mLACPCtrl:LACP: Data BPDU Rx. on port C23
0139:13:50:14.17 lacp mLACPCtrl:Manual LACP: Partner info selected for port
0139:13:50:14.17 lacp mLACPCtrl:LACP: LACP data BPDU Tx on port C23
0139:13:50:14.57 lacp mLACPCtrl:LACP: Port C23 is DOWN
I 12/18/18 13:09:28 00077 ports: port C23 in Trk1 is now off-line
0139:13:50:14.95 lacp mLACPCtrl:LACP: Port C24 is DOWN
I 12/18/18 13:09:28 00079 ports: trunk Trk1 is now inactive
I 12/18/18 13:09:28 00077 ports: port C24 in Trk1 is now off-line
logs from cisco
*Dec 18 13:07:56.622: %LINK-3-UPDOWN: Interface GigabitEthernet1/6/0/37, changed state to up
*Dec 18 13:07:56.660: %LINK-3-UPDOWN: Interface GigabitEthernet2/6/0/37, changed state to up
*Dec 18 13:07:56.788: LACP :lacp_bugpak: Receive LACP-PDU packet via Gi2/6/0/37
*Dec 18 13:07:56.788: LACP : packet size: 124
*Dec 18 13:07:56.788: LACP: pdu: subtype: 1, version: 1
*Dec 18 13:07:56.788: LACP: Act: tlv:1, tlv-len:20, key:0x122, p-pri:0x0, p:0x47, p-state:0x3D,
s-pri:0xB00, s-mac:f062.817f.0b00
*Dec 18 13:07:56.788: LACP: Part: tlv:2, tlv-len:20, key:0x1, p-pri:0x8000, p:0x1626, p-state:0x83,
s-pri:0x8000, s-mac:0000.0000.0000
*Dec 18 13:07:56.788: LACP: col-tlv:3, col-tlv-len:16, col-max-d:0x2710
*Dec 18 13:07:56.788: LACP: term-tlv:0 termr-tlv-len:0
*Dec 18 13:07:56.788: LACP: Gi2/6/0/37 LACP packet received, processing
*Dec 18 13:07:56.788:     lacp_rx Gi2/6/0/37 - rx: during state PORT_DISABLED, got event 5(recv_lacpdu) (ignored)
*Dec 18 13:07:57.623: LACP: lacp_hw_on: Gi1/6/0/37 is coming up
*Dec 18 13:07:57.623: LACP: lacp_hw_on: Gi1/6/0/37 set mode 6
*Dec 18 13:07:57.623:     lacp_ptx Gi1/6/0/37 - ptx: during state NO_PERIODIC, got event 0(no_periodic)
*Dec 18 13:07:57.623: @@@ lacp_ptx Gi1/6/0/37 - ptx: NO_PERIODIC -> NO_PERIODIC
*Dec 18 13:09:15.603: %PM-4-ERR_DISABLE: channel-misconfig error detected on Po1, putting Gi1/6/0/37 in err-disable state
*Dec 18 13:09:15.607: LACP: lacp_hw_off: Gi1/6/0/37 is going down
*Dec 18 13:09:15.607: LACP: if_down: Gi1/6/0/37
*Dec 18 13:09:15.607: LACP: lacp_hw_off: send pdu out Gi1/6/0/37
*Dec 18 13:09:15.607: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Dec 18 13:09:15.607: LACP: lacp_send_lacp_off: (Gi1/6/0/37) About to send the 110 LACPDU
*Dec 18 13:09:15.607: LACP :lacp_bugpak: Send LACP-PDU packet via Gi1/6/0/37
*Dec 18 13:09:15.607: LACP : packet size: 124
*Dec 18 13:09:15.607: LACP: pdu: subtype: 1, version: 1
*Dec 18 13:09:15.607: LACP: Act: tlv:1, tlv-len:20, key:0x1, p-pri:0x8000, p:0xE26, p-state:0x1,
s-pri:0x8000, s-mac:00b7.717f.4dcc
*Dec 18 13:09:15.607: LACP: Part: tlv:2, tlv-len:20, key:0x122, p-pri:0x0, p:0x48, p-state:0x3D,
*Dec 18 13:09:15.607: LACP: col-tlv:3, col-tlv-len:16, col-max-d:0x8000
*Dec 18 13:09:15.607: LACP: term-tlv:0 termr-tlv-len:0
*Dec 18 13:09:15.607: LACP: lacp_write: LACP 124 bytes out Gi1/6/0/37
*Dec 18 13:09:15.608:     lacp_ptx Gi1/6/0/37 - ptx: during state SLOW_PERIODIC, got event 0(no_periodic)
*Dec 18 13:09:15.608: @@@ lacp_ptx Gi1/6/0/37 - ptx: SLOW_PERIODIC -> NO_PERIODIC
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 lacp_action_ptx_slow_periodic_exit entered
*Dec 18 13:09:15.608: LACP: lacp_p(Gi1/6/0/37) timer stopped
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 lacp_action_ptx_no_periodic entered
*Dec 18 13:09:15.608:     lacp_rx Gi1/6/0/37 - rx: during state CURRENT, got event 1(port_disabled)
*Dec 18 13:09:15.608: @@@ lacp_rx Gi1/6/0/37 - rx: CURRENT -> PORT_DISABLED
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 lacp_action_rx_current_exit entered
*Dec 18 13:09:15.608: LACP: lacp_c(Gi1/6/0/37) timer stopped
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 lacp_action_rx_port_disabled entered
*Dec 18 13:09:15.608:     lacp_mux Gi1/6/0/37 - mux: during state COLLECTING_DISTRIBUTING, got event 6(outof_sync)
*Dec 18 13:09:15.608: @@@ lacp_mux Gi1/6/0/37 - mux: COLLECTING_DISTRIBUTING -> ATTACHED
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 lacp_action_mx_cd_exit is entered
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 lacp_action_mx_attached entered
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 Disabling collecting and distributing
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 set to UNSELECTED
*Dec 18 13:09:15.608:     lacp_mux Gi1/6/0/37 - mux: during state ATTACHED, got event 3(unselected)
*Dec 18 13:09:15.608: @@@ lacp_mux Gi1/6/0/37 - mux: ATTACHED -> DETACHED
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 lacp_action_mx_detached entered
*Dec 18 13:09:15.608: LACP: Gi1/6/0/37 Detaching mux from aggregator
*Dec 18 13:09:15.608: LACP: HA: Syncing LACP IDB GigabitEthernet1/6/0/37
*Dec 18 13:09:15.608: LACP: HA: Sync LACPIDBs
*Dec 18 13:09:15.608: LACP: HA ISSU: xmit xform
*Dec 18 13:09:15.608: lacp_handle_standby_port_internal called, depth = 1
*Dec 18 13:09:15.608: LACP: lacp_handle_standby_port_internal: No Standby port found for LAG 1
*Dec 18 13:09:15.609: LACP: lacp_w(Gi1/6/0/37) timer stopped
*Dec 18 13:09:15.609: LACP: lacp_c(Gi1/6/0/37) timer stopped
*Dec 18 13:09:15.609: LACP: lacp_p(Gi1/6/0/37) timer stopped
*Dec 18 13:09:15.609: LACP: lacp_t(Gi1/6/0/37) timer stopped
*Dec 18 13:09:15.609: %PM-4-ERR_DISABLE: channel-misconfig error detected on Po1, putting Gi2/6/0/37 in err-disable state
*Dec 18 13:09:15.619: LACP: lacp_hw_off: Gi2/6/0/37 is going down
*Dec 18 13:09:15.619: LACP: if_down: Gi2/6/0/37
*Dec 18 13:09:15.619: LACP: lacp_hw_off: send pdu out Gi2/6/0/37
*Dec 18 13:09:15.619: LACP: lacp_insert_partner_cd_inhibitor: didn't change sync flag.
*Dec 18 13:09:15.619: LACP: lacp_send_lacp_off: (Gi2/6/0/37) About to send the 110 LACPDU
*Dec 18 13:09:15.619: LACP :lacp_bugpak: Send LACP-PDU packet via Gi2/6/0/37
*Dec 18 13:09:15.619: LACP : packet size: 124
*Dec 18 13:09:15.619: LACP: pdu: subtype: 1, version: 1
*Dec 18 13:09:15.619: LACP: Act: tlv:1, tlv-len:20, key:0x1, p-pri:0x8000, p:0x1626, p-state:0x1,
*Dec 18 13:09:15.619: LACP: Part: tlv:2, tlv-len:20, key:0x122, p-pri:0x0, p:0x47, p-state:0x3D,
*Dec 18 13:09:15.619: LACP: col-tlv:3, col-tlv-len:16, col-max-d:0x8000
*Dec 18 13:09:15.619: LACP: term-tlv:0 termr-tlv-len:0
*Dec 18 13:09:15.619: LACP: lacp_write: LACP 124 bytes out Gi2/6/0/37
*Dec 18 13:09:15.620:     lacp_ptx Gi2/6/0/37 - ptx: during state SLOW_PERIODIC, got event 0(no_periodic)
*Dec 18 13:09:15.620: @@@ lacp_ptx Gi2/6/0/37 - ptx: SLOW_PERIODIC -> NO_PERIODIC
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 lacp_action_ptx_slow_periodic_exit entered
*Dec 18 13:09:15.620: LACP: lacp_p(Gi2/6/0/37) timer stopped
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 lacp_action_ptx_no_periodic entered
*Dec 18 13:09:15.620:     lacp_rx Gi2/6/0/37 - rx: during state CURRENT, got event 1(port_disabled)
*Dec 18 13:09:15.620: @@@ lacp_rx Gi2/6/0/37 - rx: CURRENT -> PORT_DISABLED
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 lacp_action_rx_current_exit entered
*Dec 18 13:09:15.620: LACP: lacp_c(Gi2/6/0/37) timer stopped
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 lacp_action_rx_port_disabled entered
*Dec 18 13:09:15.620:     lacp_mux Gi2/6/0/37 - mux: during state COLLECTING_DISTRIBUTING, got event 6(outof_sync)
*Dec 18 13:09:15.620: @@@ lacp_mux Gi2/6/0/37 - mux: COLLECTING_DISTRIBUTING -> ATTACHED
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 lacp_action_mx_cd_exit is entered
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 lacp_action_mx_attached entered
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 Disabling collecting and distributing
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 set to UNSELECTED
*Dec 18 13:09:15.620:     lacp_mux Gi2/6/0/37 - mux: during state ATTACHED, got event 3(unselected)
*Dec 18 13:09:15.620: @@@ lacp_mux Gi2/6/0/37 - mux: ATTACHED -> DETACHED
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 lacp_action_mx_detached entered
*Dec 18 13:09:15.620: LACP: Gi2/6/0/37 Detaching mux from aggregator
*Dec 18 13:09:15.620: LACP: HA: Syncing LACP IDB GigabitEthernet2/6/0/37
*Dec 18 13:09:15.620: LACP: HA: Sync LACPIDBs
*Dec 18 13:09:15.620: LACP: HA ISSU: xmit xform
*Dec 18 13:09:15.620: lacp_handle_standby_port_internal called, depth = 1
*Dec 18 13:09:15.620: LACP: lacp_handle_standby_port_internal: No Standby port found for LAG 1
*Dec 18 13:09:15.620: LACP: lacp_w(Gi2/6/0/37) timer stopped
*Dec 18 13:09:15.620: LACP: lacp_t(Gi2/6/0/37) timer stopped
*Dec 18 13:09:15.621: %PM-4-ERR_DISABLE: channel-misconfig error detected on Po1, putting Po1 in err-disable state
*Dec 18 13:09:15.708: LACP: CF: sync successfully completed
*Dec 18 13:09:15.709: LACP: CF: sync successfully completed
*Dec 18 13:09:16.604: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/6/0/37, changed state to down
*Dec 18 13:09:16.609: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/6/0/37, changed state to down
*Dec 18 13:09:16.614: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to downsho
*Dec 18 13:09:17.609: %LINK-3-UPDOWN: Interface GigabitEthernet1/6/0/37, changed state to down
*Dec 18 13:09:17.614: %LINK-3-UPDOWN: Interface Vlan140, changed state to down
*Dec 18 13:09:17.619: %LINK-3-UPDOWN: Interface Port-channel1, changed state to down
*Dec 18 13:09:17.620: %LINK-3-UPDOWN: Interface GigabitEthernet2/6/0/37, changed state to downw
0 Replies 0
