port-channel not comes up
Hello, im trying configurate etherchannel between switch and router in packet tracer. Everything works fine, until i reboot devices or restart PKT activity. When i restart device or relaunch, interface port-channel 1 on router, does not come up automaticly and i must up by commands.
ROUTER CONFIGURATION
Current configuration : 1520 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
ipv6 unicast-routing
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15241RXN-
spanning-tree mode pvst
interface Port-channel1
ip address 197.240.145.1 255.255.255.192
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/0/0
ip address 195.48.75.127 255.255.255.0
ipv6 address FE80::F link-local
ipv6 address 2000:F:A:C:E:158F:6399:B663/80
ipv6 enable
interface GigabitEthernet0/1/0
no ip address
interface GigabitEthernet0/2/0
no ip address
ipv6 address 202D:890D:DA:0:1::1/80
ipv6 enable
interface GigabitEthernet0/2/0.666
encapsulation dot1Q 666
ip address 192.168.66.254 255.255.255.0
interface GigabitEthernet0/3/0
no ip address
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 195.48.75.1
ip flow-export version 9
ipv6 route ::/0 2000:F:A:C:E::1
ipv6 route 202D:890D:DA:0:2::/80 202D:890D:DA:0:1::2
ipv6 route 202D:890D:DA:0:3::/80 202D:890D:DA:0:1::2
ipv6 route 202D:890D:DA:0:4::/80 202D:890D:DA:0:1::2
access-list 1 permit 197.240.145.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
SWTICH CONFIGURATION
Current configuration : 890 bytes
version 12.1
hostname Switch
switchport mode trunk
interface GigabitEthernet1/1
interface GigabitEthernet2/1
interface GigabitEthernet3/1
channel-group 1 mode on
interface GigabitEthernet4/1
interface GigabitEthernet5/1
interface GigabitEthernet6/1
interface GigabitEthernet7/1
interface GigabitEthernet8/1
interface GigabitEthernet9/1
interface Vlan1
no ip address
shutdown
interface Vlan666
ip address 192.168.66.68 255.255.255.0
line con 0
line vty 0 4
login
line vty 5 15
login
end
Any help to solve this please?
And next problem is: Why i cannot create sub onterface on port channel?
pieterh
on the router you have no physical interface assigned to the port channel like you have on the switch
post the zipped Packet Tracer project (.pkt) file...
Hello
What are you trying to achieve here, multilink two rtrs interfaces or this it a switch with L3 routing as a rtr doesn't have PC capabilities
Also it look likes one side is a L2 aggregation and the other is L3 which will not work.
Kind Regards
Paul
