Port-channel on ASA
The pings do not go through the Port-channel. VLANs are configured. Without the Port-channel, the ping passes correctly. Devices are directly connected.
ASA config:
interface GigabitEthernet1/3
 channel-group 1 mode active
interface Port-channel10.1
 vlan 987
 nameif TEST
 security-level 100
 ip address 192.168.0.10 255.255.255.0
Switch config:
 switchport access vlan 987
 switchport mode access
interface FastEthernet0/3
 description to ASA-PO
=================================== SHOW OUTPUT ========================================
ASA# show lacp neighbor
ASA# show port-channel summary
Switch:
 switchport trunk native vlan 987 <<- remove this
Switchport trunk allow vlan 987 <<- add this
 switchport mode trunk
12 Replies 12
Mark Elsen
        - Can other traffic go through the port-channel ?
        - What error do you get for the pings ?
 M.
ASA# ping TEST 192.168.0.11
Sending 5, 100-byte ICMP Echos to 192.168.0.11, timeout is 2 seconds:
PO-TEST#ping
Protocol [ip]:
Target IP address: 192.168.0.10
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.0.11
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.168.0.10, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.11
Success rate is 0 percent (0/5)
First check vlan in SW
Second since you use subinterface then the traffic is tag and hence you can not use PO access mode in SW
You need to change of PO from access to trunk and allow vlan in trunk
MHM
I made the changes on the Switch. There is still a problem. I'm running debug on Switch and when I ping from ASA specifying source zone:
*Mar 3 00:30:55.897: ICMP: echo reply sent, src 192.168.0.11, dst 192.168.0.10, topology BASE, dscp 0 topoid 0
VLAN:
krzysztofmaciejewskiit_0-1725196902656.png   krzysztofmaciejewskiit_1-1725196926437.png
It works, but doesn't the “switchport mode trunk” command pass all VLANs? Great to know that I have to do it this way, but now I'm a little confused.
What point confuse you?
MHM
I thought the “switchport mode trunk” command allowed all VLANs by default. I'm curious, why do we have to explicitly type “switchport trunk allow vlan 987”?
I even added the “switchport trunk allow vlan all” command before you said to add the “switchport trunk allow vlan 987” directly and it didn't work.
Ok' this not effect config  what is effect config is
You are correct
Switchport mode trunk <<- allow all vlan' but I suggest
switchport trunk allow vlan 987 <<- only to allow one vlan in this trunk' since you use one subinterface in asa.
MHM
You are right, “switchport trunk native vlan 987” was the problem. As for allowing one VLAN, I realize that we should only let go of the required VLANs, but I'm in a lab environment, so I took a shortcut
That is, the problem first turned out to be “switchport mode access” and then “switchport trunk native vlan 987”, because ASA was expecting tagged traffic and I was sending untagged traffic. Am I right?
Totally right friend
MHM
This is not the first time you have helped me and then explained. Thank you.
