Port Channel using Exalt Microwave
pablorduarte69
Good Day All,
I'm using Exalt Microwave Units with Dual Polirization to Create two Point to Point Links for High Availibility Connectivity. Note This is not a "Hot Standby" system but a 1+1 configuration where both Links are Hot all of the Time.
The Bandwitdth of these hops are 10Megs each.
I will use Port Channel and Link Aggregation Protocol to combine the bandwidth to 20 Megs.
The Microwave Bridging Units are connected to the switch a Catalyst-2960 on ports Fa0/23 and Fa0/24.
Exalt recommends that the ports for the switch to be set to Speed 100 and Duplex Full for best performance.
Question I have is how do I set the Bandwidth of these ports to Only 10 Megs per port?
I have seen examples of using QOS commands but I'm not sure if this is correct.
Thanks very much for any and all assistance in this matter.
Pablo
0 Replies 0
