Port channels on Nexus 7k 10G interfaces LACP if possible
Steve Coady
Hello
I need to create a port-channel with (2) 10G interfaces on a Nexus 7010. This port channel
will connect to a Data Domain device. The Data Domain device will bundle 2 10G interfaces and give
it an ip address.
I am not too familiar with Nexus.
The vendor stated they would prefer LACP to round robin.
currently I have the interfaces as follows:
interface Ethernet8/45
description DataDomain EMC
switchport
switchport access vlan 804
spanning-tree port type edge
no shutdown
Can I just add channel-group x on each, lacp active and be done?
sMc
2 Accepted Solutions
Reza Sharifi
LACP is the only protocol supported on Nexus series devices
Just add "channel-group 10 mode active" to your physical interfaces.
In this case the portchannel id is 10, but you can use any other number you want.
Once this config is done, go under the Portchannel interface and issue "no sh" to bring up the Portcahnnel interface.
switchport
no shutdown
Hi Steve,
Yes, since you have 2 Nexus devices, I would put both connections in the same VPC. The same config for both switches:
switchport
vpc 10
no shutdown
14 Replies 14
Reza Sharifi
switchport
no shutdown
How does vPC play into this port-channel?
Each port-channel will have (2) 10G interfaces from different Nexus 7k switches.
what will that interface config look like?
sMc
The Portchannel will have one 10Gig interface to each 7k.
In order for the VPC to work correctly, the 2 7ks need to be VPCed together also.
You can check that by issuing "sh vpc" on both 7ks.
Can you provide the output of "sh vpc" and "sh run vpc" from both 7ks?
I see it
 here is what config should look like, i think
PRODUCTION DataDomain device
A-Dist (7k) & B-Dist (7k)
description DataDomainProd
switchport
channel-group 13 mode active
vpc 13
no shutdown
interface Ethernet8/46
switchport
channel-group 14 mode active
vpc 14
no shutdown
Does this look correct?
sMc
Looks correct, except the VPC number for both 7ks should be the same, if the 7ks are VPCed together.
Reza
I have (2) separate Data Domain devices 1) Prod  2). DR
I will be configuring (4) port-channels. Each pair of interfaces get's it's own vpn/portchannel #, yes?
sMc
Yes, if 7ks are 2 different devices and not connected together via a VPC. Then each side get their own Portchannel.
7k's are connected via VPC domain 1
I apologize for any confusion. Does the following look correct?
Switch-A
switchport
vpc 14
no shutdown
Switch-B
switchport
vpc 14
no shutdown
sMc
Yes, the config is correct now.
Reza
I assume the port-channel and the Vpc will automatically be created when I implement the physical interface with this command. Is that a true assumption?
sMc
Steve Coady
Reza
Thank you for the reply.
sMc
Steve Coady
Hello
Do I need to do anything with vPC?
sMc
Hi Steve,
switchport
vpc 10
no shutdown
vpc 10 where (10) is the vpc domain #?
sMc
