Port channnel error
mahesh18
Level 6
Level 6
                   Hi all,
I was trying to create port channel on 4507
I config 2 ports as trunk ports and ran this command
channel-group 10 mode active and got the error below
Command rejected (Port-channel10, Gi1/1): Either port is L2 and port-channel is
L3
L3
Can someone please tell me about this error and how to fix it?
Thnaks
MAhesh
Reza Sharifi
Hi Mahesh,
Try these command under each interface:
Switch(config)# interface range fastethernet 5/4 - 5 (Note: Space is mandatory.)
Switch(config-if)# no switchport
Switch(config-if)# no ip address
Switch(config-if)# channel-group 1 mode desirable
Switch(config-if)# end
config guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/channel.html
5 Replies 5
Reza Sharifi
Hi Mahesh,
config guide:
Hi Reza,
Many thanks again
MAhesh
Hi Mahesh.
What was the issue?
Thanks for the rating
Reza
Hi Reza,
I was trying to create port channel between 3560 and 4507  .
on 3560 i did
int port-channel 10
switchport mode trunk
int gi0/1 and gi0/2
4507
int gi0/1  and gi0/2
whenever i type command channel-group 10 mode active  it gave me error as i told earlier
as soon as i did
no switchport
no ip address  it worked ok.
now both ports are in portchannel.
So this was the issue.
Seems on 4507 we need to create  either layer 2 or layer 2 port channel.
when i type no switchport then on 4507 the port channel changed to type  layer 3.
MAhesh
Hi Mahesh,
Thanks for the update!
Reza
