Port Error Disabled on N7K-M132XP-12L module
dtran
Level 6
Level 6
Hi all, hope everyone is doing well !!
I've got a pair of N7010's in a vPC domain with some FEX's attach running NX-OS 6.0.2. I am experiencing port failures on my N7K-M132XP-12L module the port got shut down due to internal errors with Error Disabled status and I am not able to bring the port back up. I am getting the following errors when I try to reset it. Has anyone run into this issue ? I am hoping is not hardware related as my vPC peer-link is on this module and I only have a single N7K-M132XP-12L in each N7010. Replacing the module will be painful.
Thanks all in advance !! I appreciate any inputs / suggestions !!
Danny
2013 May 20 15:26:38 SEG-N7010-2 %ETHPORT-5-IF_DOWN_ADMIN_DOWN: Interface Ethernet1/10 is down (Administratively down)
2013 May 20 15:26:41 SEG-N7010-2 %ETHPORT-5-IF_ADMIN_UP: Interface Ethernet1/10 is admin up .
2013 May 20 15:26:41 SEG-N7010-2 %ETHPORT-5-SPEED: Interface Ethernet1/10, operational speed changed to 10 Gbps
2013 May 20 15:26:41 SEG-N7010-2 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/10, operational duplex mode changed to Full
2013 May 20 15:26:41 SEG-N7010-2 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/10, operational Receive Flow Control state changed
to off
2013 May 20 15:26:41 SEG-N7010-2 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/10, operational Transmit Flow Control state change
d to off
2013 May 20 15:26:41 SEG-N7010-2 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 0 of Fex 115 that is connected with Ethernet1/10 changed its s
tatus from Configured to Fabric Up
2013 May 20 15:26:47 SEG-N7010-2 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 2 of Fex 115 that is connected with Ethernet1/10 changed its s
tatus from Fabric Up to Connecting
tatus from Connecting to Active
2013 May 20 15:26:47 SEG-N7010-2 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel115: Ethernet1/10 is up
2013 May 20 15:26:48 SEG-N7010-2 %ETHPORT-5-IF_UP: Interface Ethernet1/10 is up in mode Fex Fabric
2013 May 20 15:26:51 SEG-N7010-2 %MODULE-2-MOD_SOMEPORTS_FAILED: Module 1 (Serial number: JAF1526AHFB) reported failure on ports 1/10-
1/10 (Ethernet) due to Naxos: Fatal interrupt in device DEV_NAXOS (error 0xc7202211)
2013 May 20 15:26:51 SEG-N7010-2 %MODULE-2-MOD_SOMEPORTS_FAILED: Module 1 (Serial number: JAF1526AHFB) reported failure on ports 1/12-
1/12 (Ethernet) due to Naxos: Fatal interrupt in device DEV_NAXOS (error 0xc7202211)
2013 May 20 15:26:51 SEG-N7010-2 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 2 of Fex 115 that is connected with Ethernet1/10 changed its s
tatus from Active to Disconnected
2013 May 20 15:26:51 SEG-N7010-2 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel115: Ethernet1/10 is down
2013 May 20 15:26:51 SEG-N7010-2 %ETHPORT-5-IF_DOWN_ERROR_DISABLED: Interface Ethernet1/10 is down (Error disabled. Reason:Internal Er
ror)
2013 May 20 15:26:52 SEG-N7010-2 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 2 of Fex 115 that is connected with Ethernet1/10 changed its s
tatus from Disconnected to Configured
7 Replies 7
Steve Fuller
Level 9
Level 9
How are the FEX connected? It looks odd that on FEX115 the log shows Uplink-ID 0 and Uplink-ID 2 both connected to Eth1\10.
Hi Steve !! Thanks for the response !!
I've got two ports on this linecard that went Error disabled (port e1/10 and e1/12). Port e1/10 is part of a port-channel connects to FEX 115 and port e1/12 is part of the port-channel connects to FEX 123.
Thanks Steve !!
Danny
Steve Fuller
Level 9
Level 9
Are the FEX dual-homed to both Nexus 7K? You're aware this is not a supported configuration on the Nexus 7K at this time.
Sent from Cisco Technical Support Android App
Hi Steve,
No, the FEX's are not dual-homed to the N7K. Each FEX has a port-channel with two 10GE links to a single N7K ( no dual-home).
Thanks !!
Danny
Steve Fuller
Level 9
Level 9
Sorry. Thought I'd ask to make sure. Can you post a show vpc, show fex and show port-channel 115?
Hi Steve, please see the command outputs below,
I've moved the port in error disabled status to a different port and it comes up with no errors.
sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : secondary
Number of vPCs configured         : 3
Peer Gateway                      : Enabled
Peer gateway excluded VLANs       : 301-302
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 300 seconds)
vPC Peer-link status
id   Port   Status Active vlans
1    Po110  up     1-8,10,12-21,32-33,55,64,68-69,72-73,80,88,90,96-9
                   9,102,105-106,120-122,177-178,192,220,240,250,408,
                   417,468,472,488,500,505
vPC status
id   Port   Status Consistency Reason                     Active vlans
1    Po1    up     success     success                    1-8,10,12-2
                                                          1,32-33,55,
                                                          64,68-69,72
                                                          -73,80,88,9
                                                          0,96-99,102 ....
SEG-N7010-2# sh fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
115  Row1-Rack5-N2248TP                Online     N2K-C2248TP-1GE   JAF1525BMPL
123  Row2-Rack3-N2248TP                Online     N2K-C2248TP-1GE   JAF1521AAQL
126  Row2-Rack6-N2248TP                Online     N2K-C2248TP-1GE   JAF1521ABBE
Hi Danny,
Good to hear you at least have it working now.
The ports you were using (eth1/10 and eth1/12) are part of the same port-group on the N7K-M132XP-12L module. Were/are those ports configured with the rate-mode dedicated or rate-mode shared command?
When using ports of the same port-group for FEX connectivity the port-group obviously needs to be configured with rate-mode shared as three of the four ports are disabled when using rate-mode dedicated.
Which ports have you moved the FEX to now to get it working and how are those ports configured?
