port forward help for remote desktop
Katsikantais
I'm having a problem with port forward for remote desktop.
My Cisco 2801 is connected as 2cd router. FE0/0 is my wan
and FE0/1 in my local.
On main 1st router I have ports 3389 (for remote desktop)
and 23 (for accessing the cisco) forward to cisco wan ip (fe0/0)
trying to connect to cisco with telnet on port 23 works ok
but remote desktop don't
Here is my config....
version 12.4
hostname XXXXXX
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret xxxxxxxxx
enable password xxxxxxxx
no aaa new-model
clock timezone UTC 2
no network-clock-participate wic 1
ip source-route
ip cef
no ipv6 cef
voice-card 0
username xxxxx password xxxxxxx
archive
log config
hidekeys
controller E1 0/1/0
shutdown
interface FastEthernet0/0
description wan.interface
ip address 172.xx.xx.xx 255.255.255.0
ip nat outside
ip virtual-reassembly
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
description local.interface
ip address 192.xx.xx.xx 255.255.255.0
ip nat inside
speed auto
half-duplex
no mop enabled
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.xx.xx.xx
no ip http server
ip nat inside source list 10 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.xx.xx.xx 3389 interface FastEthernet0/0 3389
ip access-list extended no_telnet
deny tcp any any eq telnet
access-list 10 permit 192.xx.xx.xx 0.0.0.255
access-list 100 deny icmp any any echo
access-list 100 permit ip any any
disable-eadi
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
login local
scheduler allocate 20000 1000
ntp source FastEthernet0/0
end
Can you please tell me what the problem with my 2801 config.
Thank you.
what happens if you change your static NAT entry to:
ip nat inside source static tcp 192.xx.xx.xx 3389 172.xx.xx.xx 3389 extendable
That means, if you use the outside interface IP address ? Include the 'extendable' keyword as well...
23 Replies 23
Hello
Your  static nat statement is fine, However this static nat statement doesn't need to be included in the generic overload nat statement, As such negate that host from the access list.
access-list 10 deny host 192.xx.xx.xx
res
Paul
Kind Regards
Paul
thanks for the reply. I got confused. What I rules I need to change please.
thanks
hi,
I change the static nat to
ip nat inside source static tcp 192.xx.xx.xx (ip of the Pc Im trying to connect) 3389 172.xx.xx.xx (wan ip of 2801 ) 3389 extendable
but didn't work...:(
Thanks for the reply.
Hello
as I stated you didn't need to change your static nat statement it was okay as it was
along as the device your trying to connect is open for port 3389 then all you need to do is change the access list to negate that host from being read.
no access-list 10
access-list 10 deny host 192.xx.xx.xx ( this is the device you need to rdp to)
lastly fa0/1 is set to H/D this is incorrect  you should set it to either autonegociste or manually the correct speed and full duplex
res
paul
Kind Regards
Paul
I did what you suggested but no luck.
Started all over to check settings.
I connected the Server to first router and remote desktop its working. So port
forward on first router is ok.
Connected back to Cisco 2801 and its not working. Can think anything else to do.
thanks
in your original post you say:
Is the Cisco the Internet edge device, that is, is:
ip nat outside
What is connected to FastEthernet0/0, and what to FastEthernet0/1 ?
I'll try to explain.
My 1st router is a mikrotik and its connect to internet.
local lan IP is 172.50.50.1 and 255.255.255.0
Cisco 2801 is connected to mikrotik from FastEthernet0/0
with static ip 172.50.50.2 and 255.255.255.0
FastEthernet0/1 is the 192.168.100/24 lan which is the Server
I'm trying to access with remote desktop.
Also I did a packet trace-sniffer. It seems that I sent packets from mikrotik to 2801 but I don't get response if that helps
thanks
if your Mikrotik is the Internet router, you are dealing with double NAT. Is there a requirement to NAT at all on the Cisco ?
I can't NAT all on Cisco.
I use mikrotik to offer free wifi to customers with hotspot
and I use cisco to give internet to offices.
thanks
what I meant was to not use NAT at all on the Cisco, and to just add the internal Cisco network to the addresses that need to be translated on the Mikrotik. Is that an option ?
Thanks for help guys,
I'll try to check mikrotik first if everything is ok and I'll try use another router instead of cisco to test it everything from the beggining.
I will post results when I have something new.
I am just thinking, why don't you connect the Mikrotik to the Cisco and just add the IP address range of the Mikrotik to the to-be-NATted addresses on the Cisco ? Then connect the Cisco directly to the Internet, that way you avoid the double NAT.
Is that physically possible ?
I can't do that. We get internet with fibre cable from our ISP and its plugged directly to Mikrotik's fibre port.
Mikrotik offers internet with hotspot to customers. I only want to use cisco to give internet to our offices (different network and subnet) and secure it so no customer can do anything. Like an extra layer of security.
I also tried and old draytek router that I had but no luck so I need to fix the nat rules in both routers.
thanks
