Port Forward on 871 Router
Doug Lockard
I need to forward port 2875 from any public address to an internal address  192.168.20.103.  I am not getting something right because it will not  work.  Below is my config.  Any suggestions?
Current configuration : 11012 bytes
! Last configuration change at 23:30:24 UTC Fri Apr 12 2002 by cisco
version 15.1
no service pad
hostname Name
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5
aaa new-model
aaa session-id common
crypto pki trustpoint TP-self-signed-501752122
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-501752122
revocation-check none
crypto pki certificate chain TP-self-signed-501752122
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 35303137 35323132 32301E17 0D303230 34313230 34313234
  385A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3530 31373532
  31323230 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  9E616FE2 89D50607 DA6B9C73 DF328C72 890E603D 8B299396 D06265B1 B0B85F75
  512E9037 A788275C 3D5AD24F 7762CB8D 8BFCF792 71D6C9F0 D0957B03 689FBD74
  54F8F208 DAEEEC6F 1C0F9E3E A262BAC3 58653A3A CAE914FB C8C4C438 A2AFA0A6
  D8DF8836 0D45CB41 3E80C328 FD561888 1C4E221C F2D626B0 6A63C8E2 BA636C9D
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 168014D3 7C91E31B 0A118C6B 969ED23D 2190FFB8 45207630 1D060355
  1D0E0416 0414D37C 91E31B0A 118C6B96 9ED23D21 90FFB845 2076300D 06092A86
  4886F70D 01010405 00038181 0016326D DD0F96E6 42DFF3CF FD36D024 50166E4F
  A8D7E7CC 93FEE468 12586FEE B2D4F100 711A84F6 26F18FA3 258852B7 70925FB8
  70EF1C1C 6CD1CDA6 C054663C 6BDFA84A 72058357 866AC963 818F86CC B7D149FE
  D4DE7FD2 09507998 AAA9792B E0FCD2AD 5A29771F 18CC48CB 9FB1032E 7BA6E7F1
  C1269DBA 792CDD46 165E4893 1A
        quit
dot11 syslog
dot11 ssid <Wireless>
vlan 2
authentication open
authentication key-management wpa
mbssid guest-mode!
ip source-route
ip dhcp excluded-address 192.168.20.1 192.168.20.99
ip dhcp excluded-address 192.168.21.1 192.168.21.99
ip dhcp pool <Name>
   import all
   network 192.168.20.0 255.255.255.0
   dns-server 4.2.2.2 4.2.2.1
   default-router 192.168.20.1
   lease 14
ip dhcp pool <Wireless>
   import all
   network 192.168.21.0 255.255.255.0
   default-router 192.168.21.1
ip cef
no ipv6 cef
archive
log config
  hidekeys
username cisco privilege 15 secret 5
no ip ftp passive
class-map type inspect match-all sdm-cls-VPNOutsideToInside-1
match access-group 103
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any sdm-cls-access
match class-map SDM_HTTPS
match class-map SDM_SSH
match class-map SDM_SHELL
class-map type inspect match-all sdm-cls-VPNOutsideToInside-3
class-map type inspect match-all sdm-cls-VPNOutsideToInside-2
match access-group 104
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_VPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all SDM_VPN_PT
match access-group 102
match class-map SDM_VPN_TRAFFIC
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-all sdm-access
match class-map sdm-cls-access
match access-group 101
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-VPNOutsideToInside-1
class type inspect sdm-cls-VPNOutsideToInside-1
  inspect
class type inspect sdm-cls-VPNOutsideToInside-2
  inspect
class type inspect sdm-cls-VPNOutsideToInside-3
  inspect
class class-default
  drop
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
class type inspect SDM_VPN_PT
  pass
class type inspect sdm-access
  inspect
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-VPNOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-VPNOutsideToInside-1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key key address <peer address>
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to<peer address>
set peer <peer address>
set transform-set ESP-3DES-SHA2
match address <Address>
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ETH-WAN$
ip address <External IP> 255.255.255.252
ip nat outside
  ip virtual-reassembly in
zone-member security out-zone
duplex auto
speed auto
interface Dot11Radio0
no ip address
ip nat inside
encryption vlan 2 mode ciphers aes-ccm tkip
broadcast-key vlan 2 change 30
ssid <WIreless>
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $FW_INSIDE$
ip address 192.168.20.1 255.255.255.0
ip nat inside
zone-member security in-zone
interface Vlan2
no ip address
bridge-group 1
interface BVI1
ip address 192.168.21.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http secure-server
ip dns server
ip nat inside source static tcp 192.168.20.103 2875 interface FastEthernet4 2875
ip nat inside source static tcp 192.168.20.103 23 interface Vlan1 23
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 <Exteranl IP>
ip access-list extended ACLIN
remark CCP_ACL Category=2
deny   ip 192.0.0.0 0.255.255.255 <Peer Network> 0.255.255.255
permit ip 192.0.0.0 0.255.255.255 any
ip access-list extended <Name>
permit ip 192.168.20.0 0.0.0.255 <Peer Network> 0.0.0.255
permit ip 192.168.21.0 0.0.0.255 <Peer Network> 0.0.0.255
ip access-list extended SDM_AH
remark CCP_ACL Category=1
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_HTTPS
permit tcp any any eq 443
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
permit tcp any any eq 22
logging esm config
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.0.0.0 0.255.255.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 67.139.127.72 0.0.0.7 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip any any
access-list 102 remark CCP_ACL Category=128
access-list 102 permit ip host <peer Address> any
access-list 103 permit ip <Peer Network> 0.0.0.255 192.168.20.0 0.0.0.255
access-list 103 permit ip <Peer Network> 0.0.0.255 192.168.21.0 0.0.0.255
access-list 104 permit ip <Peer Network> 0.0.0.255 192.168.20.0 0.0.0.255
access-list 104 permit ip <Peer Network> 0.0.0.255 192.168.21.0 0.0.0.255
access-list 150 permit tcp any host External IP eq telnet
access-list 150 permit ip host 192.168.20.103 any
route-map SDM_RMAP_1 permit 1
match ip address ACLIN
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
transport input all
scheduler max-task-time 5000
end
wpa-psk ascii 0 <PSK>
  inspect
  inspect
  inspect
class class-default
  drop
Just put this command in config mode to get sure this is the culprit: ip inspect log drop-pkt
When trying to access the service from outside you should see a log telling you why it was dropped.
To remedy:
access-list 190 permit tcp any host 192.168.20.103 eq 2875
class-map type inspect TCP_2875
match access-group 190
class type inspect TCP_2875
  inspect
Regards.
Alain
5 Replies 5
Doug Lockard
Does anyone have a suggestion?  This is probably straight forward for experienced cisco engineers.
Hi Doug,
Configure the static NAT statement with IP address of the interface FastEthernet4 like below...
ip nat inside source static tcp 192.168.20.103 2875 206.206.206.2 2875
And why you have this below statement, what is it for?
Please rate all the helpfull posts.
Naidu.
  inspect
  inspect
  inspect
class class-default
  drop
To remedy:
  inspect
Regards.
Alain
Thanks for the replies.  I'm working with the customer now to test it out.
Thank you very much for your help!  That resolved the issue and the customer is happy.
Doug
