Port Forwardin in Cisco 877
julianalim
Does Cisco 877 supports port forwarding? If yes, how is it done?
lee.reade
Level 4
Level 4
You can do this via NAT, where you will forward a specific incoming tcp port to a specific inside host on either the same or different tcp port;
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_addr_consv_ps6350_TSD_Products_Configuration_Guide_Chapter.html
LR
