Bookmark
Subscribe
560
port forwarding ranges in ios
jamey
Level 4
Level 4
Is this possible? for example, i want to forward udp 16000-16500 to an internal IP on my soho 871 for voip. I can't find any info on IOS range port forwarding.
Thanks!
wbreitzke
I guess you should be able to configure the udp packets to internal IP using this command.
ip nat inside source static udp 10.1.1.1 443 192.168.1.1 443 ext
