Port forwarding to a inside host over vpn
netrusoff
Hi there!
I have the following topology       192.168.0.0/24----->ROUTER1(outside_ip1)-----vpn l2l---->(outside_ip2)ROUTER2-----> 192.168.100.0/24
hosts from 192.168.0.0/24 can easily ping hosts from 192.168.100.0/24
i need to make port forwarding for following scenario - users will connect from internet to ROUTER1 outside_ip1:443 and they sholud get to 192.168.100.3:443
so i make nat rule like this: ip nat inside source static tcp 192.168.100.3 443 outside_ip1 443
show ip nat translations shows me that translations are well performed but still, users from internet can not get access to 192.168.100.3:443
i tried to ping 192.168.100.3 from ROUTER1 using it's inside interface as a source of icmp and it was succeed, but when i'm tring to ping 192.168.100.3 from ROUTER1 without mentioning source interface ping got fail response((
help me please, i can't figure out what is wrong
"i need to make port forwarding for following scenario - users will connect from internet to ROUTER1 outside_ip1:443 and they should get to 192.168.100.3:443"
Who needs to access 192.168.100.3:443, users from the Internet accessing your ROUTER1 first, or internal users from the 192.168.0.0 network ?
Either way, if users from the public Internet need access to 192.168.100.3:443, they wouldn't need to go through ROUTER1, and you could configure the following on ROUTER2:
ip nat outside source static tcp outside_ip2 443 192.168.100.3 443
yeah, i'm understand that it's a bit weird that users have to connect to R1 outside_ip1 to reach 192.168.100.3 but my boss insisted to do it that way. This is because we need to hide the fact that network behind ROUTER1 belongs to our company that nested in 192.168.100.0/24
How can i do that strange port forwarding and why your suggestion "ip nat outside source static tcp outside_ip2 443 192.168.100.3 443" is not working on R1 with outside_ip1?
How do you know that outside users can't reach 192.168.100.3:443? I mean maybe that can reach it but return traffic is dropped.
Which router is used to reach internet by users in 192.168.100.0/24? R1 or R2?
I would check routing tables if everything looks OK there.
Also do you have ip nat inside on R1's VPN tunnel interface toward R2?
can you upload configs of both routers?
Best Regards Please rate all helpful posts and close solved questions
anyway thank you for your reply!
