port forwarding udp port range from 36000 to 59999 on cisco router
nareh84
Level 3
Level 3
hi
I am currently working on expressway. in order for it to work i have to do port forwarding for udp range (36000 to 59999). is there a way to configure port forwarding using few commands
Naray
where are you intending to do port forwarding?
i want to do udp portforwarding towards cisco expressway E virtual machine. i have to forward a range of udp ports on Cisco Router
Ganesh Hariharan
Hey Naray,
Have a look on the below link for better understanding.
http://slaptijack.com/networking/cisco-nat-and-port-range-resolution/
Hope it Helps
-GI
it only do portforwarding for tcp. can you please share config for udp portforwarding
