Port Forwarding
dpatkins
Level 7
Level 7
I am working on a scenario with some private addressing behind a router. WE would like to allow a user to RDP to two servers behind the router that are privately addressed and we do not want to statically route the address space.
Is there a way to do port forwarding on a Cisco 1841? If so, would the user hten just RDP to the router and then have the router pass the ports to the server? Since there are two servers, would we need port 3389 and then create another for the second server?
Dwane
Jon Marshall
Dwane
You are either going to need
1) 2 public IP's, one of which could be the external interface address on the router
OR
2) You could use the external interface for both but you would need RDP to be running on 2 different ports.
So you have 2 internal servers = 192.168.5.10 & 192.168.5.11
external interface on router = fa0/1
Config for 1 - (assuming you are using the interface address for one of the servers)
ip nat inside source static tcp 192.168.5.10 3389 interface fa0/1 3389
ip nat inside source static tcp 192.168.5.11 3389 195.17.17.1 3389
** Obviously you need to own the 195.17.17.1 address and it needs to be routed to the outside interface of your 1841 by your ISP
config for 2
ip nat inside source static tcp 192.168.5.11 3389 interface fa0/1 3390
For both configs you need
int fa0/0
ip nat outside
int fa0/0
ip nat inside
where fa0/0 is the interface that connects to 192.168.5.x network.
One last point. You don't necessarily have to NAT out both. If you have no spare public IP's and you can't change the port just setup this
and then have the user RDP from that server to the other server.
Jon
Jon Marshall
Dwane
OR
config for 2
int fa0/0
ip nat outside
int fa0/0
ip nat inside
Jon
Great! Thank you very much.
