HSRP enabling
bapatsubodh
Level 7
Level 7
On which type of interfaces HSRP can be enabled on L3 switches.
I beleive it can be enabled on SVI, Routed port only. Can it be configured on port-channel interface - if yes how ?
Please share the experience?
Any link on Cisco.com?
Thanks in advance
Subodh
Edison Ortiz
Yes, you can enable HSRP on L3 Port-Channel interfaces.
A quick search in Cisco.com revealed this article:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_12c_ea1/configuration/guide/swhsrp.html
In the following procedures, the specified interface must be one of these Layer 3 interfaces:
•Routed port: a physical port configured as a Layer 3 port by entering the no switchport interface configuration command.
•SVI: a VLAN interface created by using the interface vlan vlan_id global configuration command and by default a Layer 3 interface.
•Etherchannel port channel in Layer 3 mode: a port-channel logical interface created by using the interface port-channel port-channel-number global configuration command and binding the Ethernet interface into the channel group. For more information, see the "Configuring Layer 3 EtherChannels" section.
All Layer 3 interfaces must have IP addresses assigned to them. See the "Configuring Layer 3 Interfaces" section.
HTH,
__
Edison.
