port forwarding
jrasmu
I have a little problem. I can't seem to get my gameserver working ( call of duty) at least not on my cisco router
The server shows on the server list on the internet. But users who try to connect just get an awaiting connection and then time out.
Neither can I connect through the internet to my PC via PCAnyware.. I can connect through my LAN without any problems.
My FTP server ( or me )is having the same problem. no connection.
When I replace my cisco router with my zyxel ( that came from my ISP) there are no problems connecting to my gameserver or to my PC via PCAnyware. ( FTP still doesn't work)
I list my config below.
My router : cisco 877
Please help... Thanks...
hostname router
logging buffered 51200 warnings
enable secret 5
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.xx.xx.xx 10.xx.xx.xx
ip dhcp pool DHCP
network 10.xx.xx.xx 255.255.255.0
default-router 10.xx.xx.xx
dns-server 212.xx.xx.xx 212.xx.xx.xx
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
bundle-enable
dsl operating-mode ansi-dmt
hold-queue 224 in
interface FastEthernet0
no cdp enable
spanning-tree portfast
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface Vlan1
ip address 10.xx.xx.1 255.255.255.0
ip nat inside
no ip virtual-reassembly
interface Dialer0
ip address negotiated
ip access-group 121 in
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin optional
ppp chap hostname
ppp chap password 7
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
no ip http server
no ip http secure-server
ip nat inside source list 40 interface Dialer0 overload
ip nat inside source static udp 10.xx.xx.10 5632 interface Dialer0 5632
ip nat inside source static tcp 10.xx.xx.10 5632 interface Dialer0 5632
ip nat inside source static udp 10.xx.xx.10 5631 interface Dialer0 5631
ip nat inside source static tcp 10.xx.xx.10 5631 interface Dialer0 5631
ip nat inside source static udp 10.xx.xx.10 28960 interface Dialer0 28960
ip nat inside source static tcp 10.xx.xx.10 28960 interface Dialer0 28960
ip nat inside source static udp 10.xx.xx.10 20510 interface Dialer0 20510
ip nat inside source static udp 10.xx.xx.10 20500 interface Dialer0 20500
ip nat inside source static tcp 10.xx.xx.10 21 interface Dialer0 21
ip nat inside source static tcp 10.xx.xx.10 20 interface Dialer0 20
access-list 10 permit 10.xx.xx.0 0.0.0.255
access-list 40 permit 10.xx.xx.0 0.0.0.255
access-list 121 permit udp any any eq bootpc
access-list 121 permit icmp any any echo
access-list 121 permit icmp any any echo-reply
access-list 121 permit icmp any any unreachable
access-list 121 permit udp any eq isakmp any eq isakmp
access-list 121 permit esp any any
access-list 121 permit gre any any
access-list 121 permit tcp any any eq ftp
access-list 121 permit tcp any any eq ftp-data
access-list 121 permit tcp any any eq 5631
access-list 121 permit udp any any eq 5631
access-list 121 permit tcp any any eq 5632
access-list 121 permit udp any any eq 5632
access-list 121 permit tcp any any eq 28960
access-list 121 permit udp any any eq 28960
access-list 121 permit udp any any eq 20510
access-list 121 permit udp any any eq 22500
access-list 121 permit ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 10 in
password
login
scheduler max-task-time 5000
end
amritpatek
Level 6
Level 6
Make sure Server is configured for Static IP Nat.Try to remove the access list and reconfigure it again.If that doesnt work try upgrading IOS version.
