Port gets LINEPROTO-5-UPDOWN often
sylvaing1
Hi, I have a 3750-24PS-E switch to which I have HID EdgeReader 40 (card access controllers running Linux BusyBox). On one of them, the switch often sends in the logs:
Apr 21 10:43:03 ... 1214: 17w3d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 21 10:43:05 ... 1215: 17w3d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to up
without %LINK-3-UPDOWN lines. Just the protocol goes down/up, not the link itself.
The counters for the port shows:
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize OutDiscards
Fa1/0/6 0 0 0 0 0 0
Port Single-Col Multi-Col Late-Col Excess-Col Carri-Sen Runts Giants
Fa1/0/6 0 0 0 0 0 0 0
and on the linux side, cat /proc/net/dev shows:
Inter-| Receive | Transmit
face |bytes packets errs drop fifo frame compressed multicast|bytes packets errs drop fifo colls carrier compressed
lo: 32896 408 0 0 0 0 0 0 32896 408 0 0 0 0 0 0
eth0: 3831171 40278 0 0 0 0 0 0 4189806 40355 0 0 0 0 0 0
I'm at lost at figuring why the protocol goes down like this. Any help would be appreciated.
Thanks.
9 Replies 9
sylvaing1
Hi, I've activated more logging on the port in question and here is what I got :
Apr 22 13:17:16 ... 1235: 17w4d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from forwarding to disabled
Apr 22 13:17:17 ... 1236: 17w4d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 22 13:17:18 ... 1237: 17w4d: %LINK-3-UPDOWN: Interface FastEthernet1/0/6, changed state to down
Apr 22 13:17:19 ... 1238: 17w4d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from disabled to blocking
Apr 22 13:17:19 ... 1239: 17w4d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from blocking to forwarding
Apr 22 13:17:21 ... 1240: 17w4d: %LINK-3-UPDOWN: Interface FastEthernet1/0/6, changed state to up
Apr 22 13:17:21 ... 1241: 17w4d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to up
Apr 22 13:17:29 ... 1242: 17w4d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from forwarding to disabled
Apr 22 13:17:30 ... 1243: 17w4d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 22 13:17:32 ... 1244: 17w4d: %LINK-3-UPDOWN: Interface FastEthernet1/0/6, changed state to down
Apr 22 13:17:32 ... 1245: 17w4d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from disabled to blocking
Apr 22 13:17:32 ... 1246: 17w4d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from blocking to forwarding
Apr 22 13:17:34 ... 1247: 17w4d: %LINK-3-UPDOWN: Interface FastEthernet1/0/6, changed state to up
Apr 22 13:17:34 ... 1248: 17w4d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to up
Hopefully, this will trigger a bit more responses ;-)
Thanks.
I am a little confused. You said that there were no %LINK-3-UPDOWN messages. Yet there they are.
-Jeff
Well, looks like that one turned out to be a bad example. Ok, how about that one?
Apr 22 14:35:07 ... 1249: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from forwarding to disabled
Apr 22 14:35:08 ... 1250: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 22 14:35:09 ... 1251: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from disabled to blocking
Apr 22 14:35:09 ... 1252: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from blocking to forwarding
Apr 22 14:35:11 ... 1253: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed
No %LINK-3-UPDOWN messages there...
I do get %LINK-3-UPDOWN from time to time. Here's the logs for the last 3 hours...
Apr 23 08:42:36 ... 1261: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from forwarding to disabled
Apr 23 08:42:37 ... 1262: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 23 08:42:39 ... 1263: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from disabled to blocking
Apr 23 08:42:39 ... 1264: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from blocking to forwarding
Apr 23 08:42:40 ... 1265: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to up
Apr 23 09:52:24 ... 1266: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from forwarding to disabled
Apr 23 09:52:25 ... 1267: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 23 09:52:27 ... 1268: 17w5d: %LINK-3-UPDOWN: Interface FastEthernet1/0/6, changed state to down
Apr 23 09:52:27 ... 1269: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from disabled to blocking
Apr 23 09:52:27 ... 1270: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from blocking to forwarding
Apr 23 09:52:29 ... 1271: 17w5d: %LINK-3-UPDOWN: Interface FastEthernet1/0/6, changed state to up
Apr 23 09:52:29 ... 1272: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to up
Apr 23 09:52:45 ... 1273: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from forwarding to disabled
Apr 23 09:52:46 ... 1274: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 23 09:52:47 ... 1275: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from disabled to blocking
Apr 23 09:52:47 ... 1276: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from blocking to forwarding
Apr 23 09:52:49 ... 1277: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to up
Apr 23 10:26:20 ... 1278: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from forwarding to disabled
Apr 23 10:26:21 ... 1279: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 23 10:26:22 ... 1280: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from disabled to blocking
Apr 23 10:26:22 ... 1281: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from blocking to forwarding
Apr 23 10:26:23 ... 1282: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to up
Apr 23 11:15:20 ... 1283: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from forwarding to disabled
Apr 23 11:15:21 ... 1284: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 23 11:15:23 ... 1285: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from disabled to blocking
Apr 23 11:15:23 ... 1286: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from blocking to forwarding
Apr 23 11:15:24 ... 1287: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to up
Apr 23 11:39:00 ... 1288: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from forwarding to disabled
Apr 23 11:39:01 ... 1289: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to down
Apr 23 11:39:03 ... 1290: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from disabled to blocking
Apr 23 11:39:03 ... 1291: 17w5d: %SPANTREE-6-PORT_STATE: Port Fa1/0/6 instance 2108 moving from blocking to forwarding
Apr 23 11:39:04 ... 1292: 17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/6, changed state to up
Out of 6 times the protocol went down, only once did the link go down.
Leo Laohoo
Try enabling "spanning-tree bpduguard enable" on both ports.
Both ports? That port is connected to a device (a Linux base card access controller), not another switch.
Try new patch cable if you haven't already.
Yeah, I already tried that. I switched port today and now it's the new port (Fa1/0/7) that is ill behaving.
The unit at the other end was also changed. The only thing that is the same is the switch itself and the cable run between the patch panel and the unit itself (which is terminated by a RG45 connector connected directly into the unit).
I had this same problem with an HID Edgereader.  When I looked up the edgereader, it showed that it  was PoE or DC power available.  The device we had was plugged into the DC power supply.  When I shut PoE off of the port, it resolved the issue.  The HID Edgereader cannot be plugged in both places.
