09-16-2013 02:15 PM — отредактировано 03-07-2019 03:30 PM
The pervious network admin configured all of the uplink ports as access ports instead of trunk ports. We now need a second vlan on a switch. My boss (the old network admin) prefers that I just configure static routes to make it work instead of a trunk port. But I trying to get the trunk port to work.
Right now we have 1 WS-C4506 and then we have all of our switches connected to it.
We need to go from the 4506 to a WS-C3560G-24TS which will then connect to another switch that will be on a different (new) vlan.
Vlan 2 and 3 needs to access the new vlan 5.
I configured the trunk but vlan 2 and 3 can ping the gateway (configured on the 4506) for vlan 5 but cannot access the test machine plugged into the 3560. (I'm using a test machine until the switch is ready to be configured and installed). I can access machines on the 3560 on vlan 2. Vlan 2 is the native vlan.
4506-----
interface GigabitEthernet2/4
description uplink
switchport trunk native vlan 2
switchport trunk allowed vlan 2,5
switchport mode trunk
interface Vlan5
description *** SLC Cloud ***
ip address 10.10.5.1 255.255.255.0
ipx network 5
C 10.10.5.0 is directly connected, Vlan5
And the vlans are displayed under show vlan
3560------
vlan 2
name vlan A
vlan 5
name Vlan B
interface GigabitEthernet0/1
description uplink
interface GigabitEthernet0/22
switchport access vlan 5
switchport mode access
switchport nonegotiate
interface Vlan2
ip address 10.10.2.2 255.255.255.0
ip helper-address 10.10.3.3
no ip route-cache
ip default-gateway 10.10.2.1
Does anyone have any ideas why the trunk isnt' working.
дата 09-16-2013 05:18 PM
Check your setup. On both switches do a show vlan to make sure both vlan 2 and 5 show active . Also on the second switch how are addresses being alocated, static or dhcp. If using dhcp then on the users port add the "switchport host" command ,all user ports should have this. Do you have L1 connections, do the ports show active ? How do you know the trunk isn't working ??? One of the problems with forcing on a trunk is you don't really know if the trunk is working . you could try " switchport mode dynamic desirable" on each side and see what happens . The config looks ok to me . Maybe you can post a show int trunk for both sides and show cdp neigh for both sides.
дата 09-17-2013 09:09 AM
The devices on vlan 5 are using static IPs. The devices on subnet 2 are using DHCP and they work. The ports do show active. Vlan 5 works on the core switch( (4506) but doesn't work as an additional vlan on the 3560.
Thanks for taking time to look at my question.
дата 09-17-2013 01:31 AM
Can you provide the full configs on both switches (omitting any passwords etc)?
I am guessing you can ping the SVI of Vlan 5 from the switch?
Can you do a #show int trunk on both switches and post the results?
Does the MAC address of the Vlan 5 SVI appear in the ARP cache of the 4506?
дата 09-17-2013 08:48 AM
Show int trunk 4506----
Port Mode Encapsulation Status Native vlan
Gi2/4 on 802.1q trunking 2
Port Vlans allowed on trunk
Gi2/4 2,5
Port Vlans allowed and active in management domain
Gi2/4 2,5
Port Vlans in spanning tree forwarding state and not pruned
Gi2/4 2,5
Show int trunk 3560----
Gi0/1 on 802.1q trunking 2
Gi0/1 2,5
Gi0/1 2,5
Gi0/1 2,5
The Mac address of the machine on vlan 5 does show in the ARP cache on 4506.
4506 Config (removed ports to limit the size of output):
! Last configuration change at 13:28:20 MDT Mon Sep 16 2013 by
! NVRAM config last updated at 09:06:21 MDT Tue Sep 17 2013 by
version 15.0
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service compress-config
boot-start-marker
boot system bootflash:cat4500-entservicesk9-mz.150-2.SG4.bin
boot-end-marker
aaa new-model
aaa session-id common
clock timezone MST -7
clock summer-time MDT recurring
ip subnet-zero
no ip domain-lookup
ip vrf mgmtVrf
appletalk routing
ipx routing 000d.65f3.1bc0
power redundancy-mode redundant
spanning-tree mode mst
vlan internal allocation policy ascending
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
description uplink
interface Vlan2
ip address 10.10.2.1 255.255.255.0
ip helper-address 10.10.3.20
ipx network 2
interface Vlan3
ip address 10.10.3.1 255.255.255.0
ipx network 7
interface Vlan5
ipx network 5
ip forward-protocol udp 10001
ip route 0.0.0.0 0.0.0.0 10.10.1.3
no ip http server
no ip http secure-server
snmp-server community RO
snmp-server community RW
control-plane
line con 0
stopbits 1
line vty 0 4
password 7 x
transport input ssh
line vty 5 15
transport input ssh
ntp clock-period 17179720
ntp server 10.10.3.15
end
3560----
! Last configuration change at 13:28:12 MDT Mon Sep 16 2013 by
! NVRAM config last updated at 09:07:28 MDT Tue Sep 17 2013 by
version 15.0
no service pad
boot-start-marker
boot-end-marker
aaa new-model
clock timezone MST -7 0
system mtu routing 1500
vtp domain NULL
vtp mode transparent
ip domain-name dtint.com
ip name-server 10.10.3.64
spanning-tree mode pvst
vlan 2
name A
vlan 5
name B
ip ssh time-out 60
ip ssh version 2
description Uplink
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
no ip route-cache
no ip http server
logging esm config
line con 0
password 7 x
line vty 0 3
password 7 x
length 0
transport input ssh
line vty 4
password 7 x
transport input ssh
line vty 5 14
password 7 x
transport input ssh
line vty 15
transport input ssh
end
Thanks-
дата 09-17-2013 09:21 AM
I don't see any L3 SVI on the 4506 for vlan 5 unless it's a misprint .
дата 09-17-2013 11:49 AM
I think I figured out. There isn't any L3 routing configured.
Thanks everyone who look at my question.
