Port inbound Discard High (Device Congestion)
yusuf habibi
Hi all,
What cause event on tools monitoring is "Port inbound Discard High (Device Congestion)" . everyday  events always appear on tools monitoring only for one Vlan.
I went looking for input errors on the port, but there are none, and the interface is running normal. So, what is a discard, and how do I troubleshoot it?
Regards, Habibi
5 Replies 5
Leo Laohoo
Post the output to the command "sh interface <Physical PORT>".
Hi leo,
thx for response,
already check for all physical interface and Vlan interface, zero input error count.
see the attachment, the event on monitoring tools
Regards, Habibi
Vikram Sisodia
I was looking up a similar case for ASR-9001 platform IOS XR code 4.3.2 and alerts looked like below:interface_alert.JPG
As I further checked on this the interface counters looked clean and there were no drops and signs of congestion/discards. All of the ingress and egress packets were forwarded in normal way and I could also see no dot1q frames were identified on  the interface that may have been dropped due to wrong VLAN encapsulations as per the counter explanations from below URL:
https://hasanmansur.com/2012/12/15/layer-2-discards-troubleshooting-rx-tx-discards
“InDiscards” are almost always caused by a port that is receiving tagged frames for a VLANID that that port is not a member of.
So as per the observations the reported alarm seems false and could not be related to counters on the interfaces:
The interface stats look clean and I do not see any discards for legitimate traffic:
Statistics for interface GigabitEthernet x/x/x/x (cached values):
Ingress:
    Input total bytes           = 33080084
    Input good bytes            = 33080084
    Input total packets         = 184799
    Input 802.1Q frames         = 0
    Input pause frames          = 0
    Input pkts 64 bytes         = 67504
    Input pkts 65-127 bytes     = 57148
    Input pkts 128-255 bytes    = 36526
    Input pkts 256-511 bytes    = 3825
    Input pkts 512-1023 bytes   = 16717
    Input pkts 1024-1518 bytes  = 3079
    Input pkts 1519-Max bytes   = 0
    Input good pkts             = 184799
    Input unicast pkts          = 98431
    Input multicast pkts        = 28492
    Input broadcast pkts        = 57876
    Input drop overrun          = 0
    Input drop abort            = 0
    Input drop invalid VLAN     = 0
    Input drop invalid DMAC     = 0
    Input drop invalid encap    = 0
    Input drop other            = 0
    Input error giant           = 0
    Input error runt            = 0
    Input error jabbers         = 0
    Input error fragments       = 0
    Input error CRC             = 0
    Input error collisions      = 0
    Input error symbol          = 0
    Input error other           = 0
    Input MIB giant             = 0
    Input MIB jabber            = 0
    Input MIB CRC               = 0
Egress:
    Output total bytes          = 30648266
    Output good bytes           = 30648266
    Output total packets        = 96223
    Output 802.1Q frames        = 0
    Output pause frames         = 0
    Output pkts 64 bytes        = 593
    Output pkts 65-127 bytes    = 22117
    Output pkts 128-255 bytes   = 36792
    Output pkts 256-511 bytes   = 16198
    Output pkts 512-1023 bytes  = 17120
    Output pkts 1024-1518 bytes = 3403
    Output pkts 1519-Max bytes  = 0
    Output good pkts            = 96223
    Output unicast pkts         = 95850
    Output multicast pkts       = 373
    Output broadcast pkts       = 0
    Output drop underrun        = 0
    Output drop abort           = 0
    Output drop other           = 0
    Output error other          = 0
"Drops for unrecognized upper-level protocol" means that we've received
packets of a type that you haven't configured and therefore don't have a
handler for in the interface protocol handling chain.
That may be (and most likely is) expected and purely cosmetic.
Examples:
- other side (switch) has CDP configured but you don't have CDP configured on this end
- someone on the Ethernet is sending IS-IS hellos but you don't have IS-IS configured on this end
- someone on the Ethernet is sending IPv6 neigbor discovery packets but you don't have IPv6 configured on this end
It may be worth checking:
- do these packets increment periodically (i.e. one packet every 30 sec or so)?
- are there any obvious features (CDP is a good candidate) that you haven't configured but the far-end (switch, or if it's a crosslink, then
the connected peer) has?
Otherwise capture & decode the packets, and perhaps reviewing the config will already give the answer in a couple of seconds.
If a 7600/ 6500 port is connected to the ASR9000 and input error increment due to 'unrecognized upper-level protocol', then to avoid various l2 packets reaching ASR9000, you can use:
switchport nonegotiate - disable Dynamic Trunk Protocol (DTP) on the port
no cdp enable - to disable running Cisco Discovery Protocol (CDP)
no vtp - to disable sending VLAN Trunking Protocol(VTP) frame
spanning-tree bpdfilter enable - To enable BPDU filtering on the interface
UDLD: If you are running CatOS try “set udld disable x/y” or “udld port disable” under the interface if you have IOS on the 6500.
LLDP: (new addition) switches by default have lldp enabled that could be, like CDP, be perceived as an unrecognized upper level protocol on the ASR9000.
alfhafarrel
I have this problem too, since i was upgrade my firmware ACI, the discards was appears, usually the disacrds could be hide with bcm-shell command, but after upgraded the firmware the bcm-shell command couldn't affected to hide the discards.
Is there any others solution for these issues?.
Many thanks,
Farrel
