Showing results forĀ
Search instead forĀ
Did you mean:Ā
Port is errdisabled due to Port # transient TX_Pb error
mahesh18
Level 6
Level 6
Hi all,
on 6509 on switch 1 port is errdisabled due to
extende: %PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 1 is experiencing the following error: Port #44 transient TX_Pb error
this is from sh log.
all others ports are ok.
when i do sh mod on device  it shows
Mod  Online Diag Status
  1  Minor Error
also when i run sh diagnostic mod 1
         sh diagnostic mod 1
Current bootup diagnostic level: complete
Module 1: 48-port 10/100/1000 RJ45 EtherModule  SerialNo :
  Overall Diagnostic Result for Module 1 : MINOR ERROR
  Diagnostic level at card bootup: complete
  Test results: (. = Pass, F = Fail, U = Untested)
    1) TestScratchRegister -------------> .
    2) TestNonDisruptiveLoopback:
   Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
   Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
         .  .  .  .  .  .  .  .  .  F  .  .  .  .  .  .  .  .  .  .  .  .  .  .
    3) TestLoopback:
    4) TestNetflowInlineRewrite:
    5) TestAsicMemory ------------------> U
    6) TestEobcStressPing --------------> U
    7) TestFirmwareDiagStatus ----------> .
    8) TestVDB -------------------------> .
Right now port is in errdisabled state and we did shut and no shut no luck.
can some one explain me this
TestNonDisruptiveLoopback:  what is this and how it is permormed ?
also  if singe port is errdisabled due to hardware error will that cause the  minor error on module itself??
thanks
mahesh
Yogesh Ramdoss
Mahesh,
Log message indicates that mod #1 experiencing Transmit Packet Buffer (PB) error.
Details of this specific test:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/diagtest.html#wp1014775
I would recommend you set the diagnostic level to complete and re-seat mod #1. If the issue persist, we may need to replace it.
- Yogesh
